Question about Linksys Wireless-G WMP54G 802.11g/b
Wmp54gv4 pci driver will not install.
Error during installation is "the data is invalid".
This card was moved from one pc to another. When it wouldn't install, I moved it back and it still works in first pc, so I know the card works.
Tried different slots - same error. Tried disabling WZC - same error.
It took the Ralink driver (rt2500) to get it to work on first pc, and that's the driver I'm using.
Both pc's are running XP sp3.
The first pc (where the card works) uses WZC - not the Linksys monitor. I've tried cofiguring the card both ways to no avail.
HELP!
  • 2 more comments
  • ptd323 Jan 26, 2009
    I have uninstalled twice (nowhere to found) to no avail. I ALWAYS install driver first, pwr dn, install card, pwr up, finds network controller but has same problem every time installing driver.
    Thanks for responding
    Different mobo - KT3 Ultra2CE MS 6380E ver 1.0
    no probs at all w/pc
  • Mark Egan May 11, 2010
    Same mobo on both computers?
    No other issues with the computer your trying to use the card with?
    Uninstall any occurances of the driver.
    Reboot. Make sure the driver is nowhere to be found.
    Follow the recommended installation procedure again, which normally says to install the driver first, before installing the card.
    Reply back what you find, and I will look into this deeper.
    President:
  • 1,214 Answers
Are you using the latest Ralink driver www.ralinktech.com , and, from the docs they provide, they indicate -
Ralink RT61 and RT2500 series miniport drivers require NDIS 5.0, NDIS 5.1 or NDIS 6.0 to operate in Microsoft Windows. NOTE: UNINSTALL OEM PROVIDED PACKAGE BEFORE RUNNING THIS RALINK PACKAGE.
Confrim these instructions have been followed.
You can also contact them.
Sorry I can't provide an exact solution, but this should get you on track, and it's the type of problem that likely only Ralink knows about, if at all.
Posted on Jan 26, 2009
Gigaware camera driver won't install
This solution has helped a lot of people. The cause of the problem has
been known already and is explained clearly how to fix the issue on the
site link below.
'Invalid Drive during installation
Fixing Invalid Drive Error 1327
May 04, 2009 | Radio Shack VGA PC Camera Webcam
Would like to install the adapter on a vista 64 bit pc
I'm sorry to say this but Linksys don;t have any driver made for a 64 bit computer for this adapter and that is the reason why it wont work with a 64 bit computer.......
Jan 15, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
I have a KWORLD PLUS TV HYBRID PCI (DVB-T 210SE) TV card which I used on my previous PC running Windows XP. I have bought a new PC running Windows Vista and have installed the TV card. I also installed...
I had the invalid floating point error..this only happened after I installed vista service pack 1 on my vista x64 machine. After much hunting around I used the following tuner software which seems to have resolved the problem (still using the v1.3.3 driver).
software:
http://www.chris-tv.com/download.html
I am using the chrisTV lite version which is free and seems to have got rid of the problem. I hope that helps.
Nov 05, 2008 | Computers & Internet
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
System do not reconize the PCI card
Does it ask for a driver to be installed? Or have you got the wireless version of the mobo that needs an ASUS WiFi-b add-on card with an omni-directional antenna?
Like on the previous version of the mainboard, the PCB contains five PCI slots and an exclusive WiFi slot, in its left part. By the way, when you install the original WLAN card from ASUS into this slot, the last PCI becomes unavailable. Now let’s examine the card, too.
The card supports the wireless networking protocol IEEE 802.11b, describing data-transfer rates up to 11Mb/s. Using the software that accompanies the card, you can use it in the Ad Hoc as well as in the Infrastructure mode, and the card can perform the functions of a programmable access point, providing connections to 31 clients. Thus, the owner of the WiFi-b kit can easily deploy wireless networks and connect to existing ones.
Jul 11, 2008 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
Error code during adobe acrobat 7.0 install
Hit Start, Run and type Regedit
Find the following HKEY_CURRENT_USER\Software\Microsoft\Windows| CurrentVersion\ Explorer\User Shell Folders
In the right pane - see if these is any entries which has an F or any other alphabelts not C (your OP folder) modify data to C:\
Hopefully it works for others.
Jun 05, 2008 | Adobe Acrobat 7.0 for PC
Samsung mobile phone usb problem
When you try to load up the drivers for the device you get an error that states that your data is invalid. Here is the fix as I found it on the web. I wish that I had marked where I found it, but didn’t. Why do I get the message "data is invalid" when installing a device driver under WindowsXP? This error appears to be due to a protection problem in the Windows registry and can occur with a variety of drivers (sound cards and SCSI drivers have been reported). To fix this problem, go to Start, Run... and type "regedit" without the quotes to run the Registry Editor. Navigate to: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ENUM\PCI You will see a number of keys of the form "VEN_xxxx", where xxxx are strings like "1102&DEV_0004&SUBSYS_00011103&REV_04". Under each of these folders will be another folder with a long numerical name. Open each folder and look for the "DeviceDesc" which matches the hardware you are trying to install. Right Click on the "VEN_xxxx" for that device and select 'Permissions' and then tick "Allow" for "Full Control". Close Regedit and then continue with the installation of your device.
Jun 02, 2008 | Pioneer DE-U7001 (DEU7001) Drive
Win XP Network card driver problem
Its a driver issue or a hardware issue. meaning that yourn etwork card may be fried. could have static damage. or your not downloading the correct version of your drivers.
Nov 04, 2007 | Compaq Presario Notebook
PC-CAM 300 Driver installation problem
hi
I am waseem my camera canon ixy digital 300 drivermodel no :pc 1008 problem is i search internet you solution my problem
i watting your anser
Sep 12, 2005 | Creative Labs PC-Cam 300 Digital Camera
Linksys Wireless-G WMP54G 802.11g/b Logo
471 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
