Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Draw won't open or close smoothly
Hello there. The top drawer of my dishwasher won't open smoothly.Gets jammed and have tried to look behind the draw to see if something has fallen down..nothing. Any help would be great Thankyou
  • Helen Monger Jul 18, 2007
    Will let you know...thankyou
  • Helen Monger Jul 21, 2007
    Hello there...tried your fix but it is still jamming
    Best regards
    Helen
    Novelist:
    Scholar:
  • 84 Answers
Hi warie...I'm afraid that I cannot claim to be knowledgeable in this field, however, upon studying the User's Guide for your product, I think it might just simply have the Lock, or Child Lock engaged. Both of the issues are referenced on Pages 2 and 3 of your User's Guide, and again in the Troubleshooting Section, specifically on Page 27. If your User's Guide has already walked through the pearly gates of manuals, you may download a copy by clicking on the URL below......good luck my friend http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Posted on Aug 03, 2007
  • 105 Answers
The drawer may not be seated in the track correctly. If it is removable, remove it & replace it, making sure the rollers are in the track. Inspect the rollers themselves, looking for breaks or cracks. If this fails, the cause may be hidden & you will need a qualified technician to uncover the reason.
Posted on Jul 18, 2007
Top drawer won't close
After completing a cycle the top drawer feels like it will not open or the top of the drawer has fallen down. I've since forced it open but, now it feels like it will not close. I did not force it to close. How do I remedy this problem?
Mar 02, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
TOP DRAW VERY TIGHT TO OPEN AND CLOSE AND NO POWER TO TOP DRAW
The power filter board at the base of the dishwasher (under the bottom drawer) has a fault which shuts power to top drawer. The drawer is tight because lid seal actualtor motors are not operting due to lack of power, Try not to push too hard as the lid seal will be damaged.
Needs a technician to fix it unless you are good at handling dishwasher repairs. This is a very difficult one to handle for the non professional. The power board is about $100 to buy,
Nov 20, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Top draw does not seal . have already replaced once but cant remember where to get part or what it is called
The most typical problem with your dishwasher is going to the lid seal motors that raise and lower the seal.thegear on it gets stripped and it slips so lid doesn't fully close on the side where motor is bad,their is 2 motors one on left and one on the right if advisable to replace both of them. By pulling the pins on drawer sides and removing front panel,then releasing the tabs on drawer slide the drawer will come out so you can also inspect the seal for rips of tears in the rubber on it but,i found 50 motors to be the problem for every seal thats bad. To replace the motors on the upper drawer the lower drawer must also be removed so the wiring to the upper drawer lid motors can be connected to the control board in the back behind the lower drawer.
Good luck.
Gene
Aug 09, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top Draw on Fisher & Paykel double draw not closing
Make sure that the retaining tabs on either side of the drawer at the lower front are engaged properly. They sometimes don't positively engage and you will feel the difference when the drawer is pushed. Undo the tabs and re-engage them a couple of times to check. The drawer should run smoothly without resistance when they are engaged correctly. Check how the lower drawer moves to compare.
If the drawer is returning smoothly but feels like it's striking resistance towards the rear just before it's fully home, it's likely that the hoses are kinking/fouling behind the drawer and/or that the linkage support is broken.
If you have this older style white plastic linkage rods that hold the hoses, I would strongly recommend replacing it. It's the white plastic rod that has clamps attached to it with all the power, inlet and drainage hoses running through it.
You can get the 'retro fit linkage support' from an authorised F&P parts supplier. This is a retro fit that has specifically been designed to overcome the shortfalls of the original plastic linkage support. This consists of a metal rod and mounting plate with takes over the function of the plastic drainage support.
There are detailed instrucitons with the retro fit support which explains how to fit it. It was well under $100 when I bought one and worth the investment.
Good luck and remember always turn the power off before attempting any repairs.
Jul 05, 2010 | Fisher and Paykel Dishwashers
Top dishwasher drawer will not close
As long as there is no plates or anything stopping it from closeing i will then say that there are 2 side rails that the draw glides in & out on,get down on the floor & check up underneath the draw for smooth gliding operation.also is it possible that a fork or peice of cutlery has gotten over the top & fallen down jambing the draw from closing.
May 29, 2010 | Fisher DD603B / DD603W / DD603H Dishwasher
Dishwasher lid stuck
the lids on dishdrawers are pulled down and sealed by lid activaters. there r two types, the screw type and the magnetic solonoid type. the reason your draw gets stuck is your lid activator is not releasing. there are 2 reasons for this 1st- 1 or both activators are faulty. 2nd the lid activator control board is faulty, which is located under the bottom drawer.pull the draw out and see if u can see if the lid is down on 1 side or both sides.please reply 4 more help.
May 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top draw won't close completely
Probably a blockage behind the drawer. If its an older model, the bracket that holds the hoses away from the drawer were apparently designed to fail and there is a retrofit replacement kit available if that is your problem.
Apr 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My top drawer of my Fisher and Paykel dish washer wont close tight. It seemed to be jammed and not closing unless it was pushed closed hard and then it jumped a bit now wont close tight and has no...
Make sure the unit is level. Remove drawer. On the inside of the cabnet there are the drawer runners on iether side. Behind these there are a pair catches. If one or both of these are latched back when they shouldn't be, ie. when the drawer is open, they will obstruct the drawer from closing fully and fail to hold it closed.
Hope this helps
Dec 13, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
I havve a Fisher and Paykel Dishdrawer model No. DD601v2. The top draw was stuck in the out position. I fear that the top of the shell casing of the dishwasher is rusted and is blocking the smooth...
When the machine operates a lid comes down on the top of the drawer. This may be jamming.
On the side near the front at the bottom there are 2 plastic slotted screw heads, turn these to horozontal and pull out the "screws" this will release the drawer from the runners and you can lift off the drawer and possibly see whats jamming.
Jul 03, 2009 | Dishwashers
We have a fisher Pakel dd603 2 drawer , the top draw wont close so we r trying to remove it to see what is blocking it can't figure out how to take top draw out
Hi!
There are two small clips down in the front of each drawer, one on each side. You depress these clips/tabs which are attached to the drawer slides, and then the drawer can be lifted away from the rails. You need to be very careful not to damage the hose/wire harness guide behind the drawer.
What may have happened is one of the "spring clips" on the rear of the rails has popped up when the drawer was open so the drawer will not have that "snap shut" feel you are used to when the drawer is almost all the way closed.
If you require more assistance, please ask.
Jan 29, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
177 people viewed this question
Top Fisher and Paykel Dishwashers Experts
TomDicker
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
