Question about HP DesignJet 1050c InkJet Printer
HP Designjet 1050c 070100 00AD027C Firmware Error
RPFinney
  • 385 Answers
SOURCE: hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Posted on Apr 17, 2009
antiochpc
  • 1314 Answers
SOURCE: System Error 0B000D 0000000D on display, nothing prints
Hello.
From the service manual:
System Error: 0B000D
Problem
Description:
24 V source test failure.
Corrective Action: Replace the Electronics Module
HP Part number: C6072-60146
I just looked up the pricing and it's not cheap. Let me know if I can be of further assistance.
Posted on May 28, 2009
  • 37 Answers
SOURCE: System Error 060308000008 on HP Designjet 1050C
that error show a problem with the pintheads
Remove ALL the Printheads and clean the flex contacts on the
Printheads and in the Carriage Assembly, if that dont solve the problem change printheads, if after that have the same problem call HP, was a hardware error.
Posted on Aug 27, 2009
SOURCE: I can't find drivers for HP Designjet 1050c
And you won't.. Because there are none as this unit is considered too OLD. Try this "work around". Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all
Posted on Feb 03, 2010
SOURCE: designjet 1050C system error 060308 00000008
Problem
Description:
One of the Printheads has an Internal Electrical Problem.
Corrective Action: Try the following:
n Remove all the Printheads and clean the flex contacts on the
Printheads and in the Carriage Assembly (Refer to Chapter 2).
n Perform the Electronic Systems Test þ Page 4-5.
n Make sure that the Trailing Cable is connected correctly.
n Replace the Trailing Cable þ Page 8-39.
n Replace the Carriage Assembly þ Page 8-44.
n If the error code continues, replace the Electronics Module þ
Page 8-25.
WARNING Only replace one component at a time and check if the error has
gone before replacing another component. Using this procedure
you will be able to determine exactly which component failed.
Posted on Feb 11, 2010
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Oct 11, 2013 | HP DesignJet 1050c plus InkJet Printer
I have a HP 44" Z3100 and after switching and saying "Initializing, please wait" it gives error 79-04 " Help needed urgently please!!!
Firmware issue:
1. Cancel all pending/que jobs
2. Disable nesting option
3. Dis connect data cable, restart the machine.. check...
4. Up load latest firmware.( read carefully read me file before up loading the firmware)
Jan 18, 2013 | HP DesignJet 1050c InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
HP Designjet 1050C Pluss - Error Code Question
Hi there only can try.
This is a firmware error, meaning your f/w simm is probably bad. You can try reseating the simm. It is behind the small panel in the back of the plotter, that is held on by 4 torq screws. Reseat all the simms that are present and see if that helps. If not, you probably need to purchase a new firmware simm.
Also try looking at
pulling the JetDirect card and then re booting it
Feb 10, 2010 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
System error 0000D8 00270435
PostScript/Firmware Error. Power the Printer OFF and ON again to see if the System Error disappears. If the Error Code reappears, then call HP support
Aug 10, 2009 | HP DesignJet 1050c plus InkJet Printer
System Error 060308000008 on HP Designjet 1050C plus
Apr 30, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
Mar 12, 2009 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
1,071 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
