Mitsun 5.1 home theater sub woofer display not working
Lcd disply back light only working letters not found
SirHanz
  • 145 Answers
SOURCE: jvc rx-e100rsl home cinema control center
unless there are some other connectors that may be used, i would think that the issue would be resolvable thru the system settings menu, there may be a speaker arrangement setting somewhere in the menus. The Sub is a .1 setting like 5.1 or 7.1, perhaps even 2.1 where the beginning number is the speaker channels and .1 is the sub. I would think with the sub being on a mono channel it woul/should work with any setting. If there is any more info you could supply I will further research this issue and try to help you get the sub working.
Posted on Jan 27, 2008
SOURCE: RCA Home Theater Receiver won't work
I had the same problem but it happened 2 years ago. i went out and bought a new receiver for $200. The RCA receiver has flaws and isn't worth fixing
Posted on Feb 16, 2008
  • 4234 Answers
SOURCE: Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Posted on Jul 15, 2008
  • 93 Answers
SOURCE: Problem w/ Panasonic SA-HT700 speakers
Let me show how to resolve your problem since you are not very good at this system.
A/V troubleshooting 101:
Remember the 2 speakers that you mentioned before that it worked.First,locate the one speaker output that work for you before(ex. front left)you will use this speaker output to connect each one of the speaker and leave the system on either tuner(radio with a proper station=101.3) or a dvd with sound,this way,you are troubleshooting two things for sure A. be sure all your speakers do work and B. your source is working.
After you test all the speakers with the same speaker output which had confirmed the speakers are working,that particular speaker output is working and also your source is working,send me an email and i will show the next step.
However,for any reason,if one of those speaker got no sound from the same speaker output connection,please do not waste anymore time,should take it back to the place you bought it from and get our money back and try to buy the A/V system separately(A/V receiver with speakers in one package, separate dvd player,etc.)
Cheers,
solutiondoct
Posted on Nov 06, 2008
SOURCE: Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Posted on Jun 03, 2009
My S9500 seems to power up with green light but no display
Do both the LCD display and the Viewfinder not work? Or did you press the EVF/LCD button?
I can remember I had some panicking events with my camera, because I switched to a mode I did not understand (or even did not notice I did switch something) and only after intensive searching I found what I did wrong. My camera still works as it should, although I have fought severals times, now it is really defect. So don't panic or thing the worst.
Don't think you are stupid when you take the manual, to see how settings are.
Jan 14, 2014 | Fuji FinePix S9500 Zoom Digital Camera
My 5130 mobile disply damaged now its displying vertical and reversible letter displying what i do my mobile warrenty is over
when i turn on my fone, the screen remains blank but i am still able to press buttons into it. can you help?
Oct 03, 2010 | Nokia 5130 Cellular Phone
Pavilion F1703 17" LCD Monitor: my moniter lose disply but sound is there it happe...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | HP Pavilion F1703 17" LCD Monitor
We r using dell lcd 1901fp when we power on it displays for 2 sec and then disply off but power led shows on, again we poweroff and on it it shows for two sec again disply disapper kindly suggest exact...
You could have an inverter board problem. The inverter supplies high voltage to the CCFL lamp which provides the back-lighting.
For service. parts and DIY info check out LCD Parts - click in this link to their WEB site : -
www.lcdparts.net
Oct 16, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Have a 22'' Soyo LCD MT-NI-DYLM2286 and without any warning the the disply is blank ... power light comes on solid ... but no pic???
Try another known working monitor on the computer to make sure you are getting video.
If you do get video with the known working monitor then you know the original monitor is bad.
If you don't get video with the known working monitor then you know that its a problem with the computer.
Aug 28, 2009 | Computers & Internet
Having display light but display is not working
The display circuit is broken even if the LCD-panel seems to be ok. the only circuit working in the display is the one for the backlight.
This is a very common Nokia display problem.
Only solution is to change the display.
You need a T-6 Torx skrewdriver to do the job.
You can find displays for fair prise at:
www.mytrendyphone.com
This is your solution! Please vote!
Jun 27, 2009 | Nokia 3120 Cellular Phone
1208 lcd light
3230 lcd light problem
Nov 22, 2008 | Nokia 3230
 Grubhead
Grubhead
