Hi. I have a Robinhood supertub. The cold water tap flow into the tub is fine but the cold water flow into the washing machine hose is suddenly poor. The tap itself is only half turning compared to the other 3 taps and is a wee bit stiffer. Any clues? Is definitely the tub not the machine as I have checked the flow without being hooked up to the machine.
  • 1 more comment
  • Shu Tan
    Shu Tan Jul 17, 2017
    Did you ever manage to figure this out? Am having the same issue with my Supertub. So strange. I also noticed that the flow coming out of the washing machine cold water tap seems to change, sometimes it's a bit faster, sometimes it is slower.
  • Lucas Couper
    Lucas Couper Oct 14, 2017
    Hi, I have the same issue. Does anyone know the solution? It's the right hand washing machine tap that only turns half way
  • Lucas Couper
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Turn off the water supply and strip the tap, fit a new washer.
Posted on Oct 15, 2017
  • 183 Answers
SOURCE: cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Posted on Aug 22, 2007
  • 97 Answers
SOURCE: I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Posted on Jun 29, 2009
  • 59 Answers
SOURCE: I have a Fisher and Paykel ECS Gentle Annie GW52-k
Make sure there is voltage going to the valve solenoids. That is what opens up and lets water into the washer. You will have to open up the top of the washer control. The valve assembly is where the hoses screw in the back. I don't have the technical on it but most likely should be 120V. Sometimes the valve goes bad and won't open up.
Posted on Feb 17, 2010
  • 1474 Answers
SOURCE: Whirlpool WFE1070BD washing machine. The water tap
Could be dirt in the inlet valve remove the hoses and check/clean filters @this section.
Posted on Apr 05, 2010
  • 72 Answers
SOURCE: My fisher and paykel smartdrive 058 which has a
i am pretty sure its the main board, the easiest way to solve the problem is replace a the main board with a secondhand board, as well as obtaining a bag of spare parts, out a good working machine with faulty seals. You may have faulty seals if the machine is dormant for 3 years. I advise people never use washing powder in their washing machines, just use liquid detergent like Cold Power. the washing powder cakes up in the machine and when harden can be very abrasive and destroy the seals.
Posted on Dec 07, 2011
My Samsung 7.5kg top load washing machine is over there a sensor or something to correct this
it is connected to the bottom of the tub by a small hose
it sits up top and as the tub fills , air pressure acts against a preset spring tension and switches the water solenoids off at the same time it starts the wash
the problem is probably the water inlet solenoid / valve that is not working or the diaphragm is split
to test , change over the cold and hot water hoses at the taps and press the hot water button
if the flow stops at the required setting it is the cold water valve unit
Apr 06, 2017 | Samsung Washing Machines
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
How do I change the washer on a Rotec Supertub tap
Those taps are fairly hard to remove, so you'll need a big crescent spanner to remove them. I have had the same leaky tap on our supertub, but have found replacement tap washers unobtainable here in Blenheim. Please let me know if you can find any.Regards, Tom
Nov 22, 2011 | Washing Machines
Cold water seems to have started having a restricted flow and makes a noise as it fills the tub.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 28, 2011 | Washing Machines
Our machine works fine, but the water just trckles in when it adds water for the rinse cycles. It can take 20 minutes to fill the tub.
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. Replace the water valve with this part.
Jan 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The flow of the cold water seems to be restricted. The hot water pores into the tub. The cold trickles in. After disconnecting the cold hose, hot water back feeds out of the cold input side of the machine....
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Aug 16, 2010 | Washing Machines
The cold water pressure is very poor into our LG top loader washing machine. There are no blckages and the water comes out of the tap fine. The hot water is ok.
remove the hose from the water machine. there is a iron mesh that traps foreign objects from the water tap. Perhaps it is quite dirty.
May 03, 2010 | Washing Machines
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
Mar 30, 2009 | Amana DLW330RA Top Load Washer
Temperature control
hi thanks for the question . make sure the cold water tap is on . if on. no cold water. replace the water valve . thanks the appliance doc
Sep 28, 2008 | Washing Machines
Washing Machines Logo
1,664 people viewed this question
Top Washing Machines Experts
