Question about Frigidaire GLER341A Electric Dryer
Hot electrical smell
Smelled like an insulator burning then it quit heating
  • 130 Answers
Take the back panel off and look for the melted peice. then you got it.
Posted on Jan 26, 2009
Hi the fridge door inner has been very hot ,strong smell of burning but fridge is working and door no longer hot now.
The defrost timer is not shutting off the heat strips in the cabinet. The smell is the fiberglass insulation overheating. Replace the timer.
Dec 05, 2016 | Refrigerators
Why smoking engine, smelled like electrical and then power steering goes out
You may have broken a hydraulic line on your power swearing. The hot power steering fluid smells like burned electrical insulation.
May 08, 2014 | 1997 Subaru Outback
Electrical burning smell
It is hard to tell what is burning, take it to the repair shop
Mar 12, 2013 | Oster OGG61403 Microwave Oven
Smell burning insulation. the connection in the unite that the power comes into that is the junction for the various other electrical lines inside the unite gets very hot and seems to be the problem. is...
Turn the power off and make sure all connections are tight. How do you know it's getting very hot? Are you touching it? Is this an actual terminal block or a breaker or is it inside wire nuts? Are you able to check amps AND are you heating or cooling??? Thanks
Aug 19, 2017 | Fahrenheat F2543 Baseboard Heater
Electrical hot smell from fan area, not has quit
Hello, electrical hot smell from the fan area means you have a burnt fan which inturn affected other parts of the ice maker. That is the reason why the ice maker fails to start up when you plug it.
You can only fix it by replacing the fan and probably other affected areas by troubleshooting it.
There is nothing like reset.
Take care
Jul 12, 2010 | Continental PortableCE-IM65151 Ice Maker...
Smell of electrical burning.. no more heat in house!
First of all keep this in mind.
You will need to locate the wires that got hot. If you can't or if your not sure, I suggest that you call a service company. If they ok the unit and it catches on fire after wards, their insurances will cover you unit and or home if god forbid it burns. This is to be on the safe side.
Now, this is where I would look. Your element should be on it's on circuit. There should be a disconnect within reach of the air handler. Some are fused and some are not. The wires that got hot enough for you to smell them should show signs of being hot like the plastic will be melted around the wire. You said that the heater was running. Was this the first time you have used it this year? If so, are you sure it was not the dust burning off the elements? They will smell like something burning when you first turn them on each year. Although if your sure you smelled wires getting hot, please continue looking for just that. Keep in mind that the elements have 220 volts coming to them. It comes into the unit and go to a switch or relay. From there the power goes to the elements and then to a neutral. These are the wires you will need to pay the most attention to. Good luck.
Nov 23, 2009 | Heating & Cooling
BOSCH DW burned plastic smell, common problem?
I have this exact same smell issue from the back black panel at rear of dishwasher (free standing so easy to pinpoint. I replaced the old bosch with this Bosch (approx 12 months ago) for the same reason, and am extremely disappointed to have the same issue. It is almost as though the black insulation material is disintegrating? I wonder what it is made from? Smells noxious. It is very hot to touch during a cycle too. Good luck,
Fiona
May 03, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Daewoo kor-861h, electrical smell and will not heat.
Turn if off, and leave it alone, remove it, if you can remove the unit, take it in for service, something is wrong if you smell electrical, most people for some reason can smell and identify correctly electrical or at least insulation burning smells, which means something is burning internally, not safe, fire hazard, unit needs to be repaired by qualified technician or replaced with new unit, take no chances, nothing you can do to repair this, could be a shorting transformer, or shorting power cables, but to attempt to trouble shoot this with email is a long shot, and depends on your experience expertize and testing equipment.
I wish I could give you a short easy answer, but the hazard and your safety is more important than a microwave.
Will
Nov 30, 2008 | Daewoo KOR-860A Microwave Oven
Frigidaire GLER341A Electric Dryer Logo
61 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
