I have a sento sen450 universal remote control and I need codes to program a Sanyo VCR. Model no. is sanyo vx800
SOURCE: Programming a Jensen JER 422 universal remote to a Sanyo Television
To Sarah,
In order to program your TV:
1. Manually turn on your component.
2. Press and hold the component key you wish to program, in your case the TV key.
3. While holding down the component key press the four-digit code using the number keys (0-9) to enter it.
4. After the fourth number is entered, the illuminated ON-OFF key turns on. At this time, release the comonent key. If the illuminated ON-OFF key turns off, you have entered a valid code.
NOTE: For Sanyo TV it could be any of the 8 next codes:
1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
Good Luck !
Carlos Vallejo
Posted on Jan 03, 2008
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
kim_cu
  • 70 Answers
SOURCE: universal remote control nse urc22c-10
Found the manual for a URC22-10D (which should be very close) at http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=nse&dv=universalremote&md=urc22d10a&kw=&st=&ar=&dt=&so=&pg=1&file=others/nse/urc22d10a-manual.zip
Posted on Jun 21, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
SOURCE: i need remote control codes for my GE universal
Need Code for GE RC24991-B Remote Control
Posted on Jan 13, 2010
Need codes and instructions to program Sanyo universal remote B21309 to a Philips Vcr/Dvd player.
Sanyo universal remote b21309 manual - logo - Tuars.com
ititoso.tuars.com/sanyo-universal-remote-b21309-manual/
Sanyo Universal Remote B21309 Please help find the manual for Question AboutSanyo Universal ... RMT-D153a RM-AX4000 Manual PDF instruction manual.
Sanyo Universal Remote RMT-U100 User's Guide ...
tv.manualsonline.com > ... > Sanyo Universal Remote
Sanyo RMT-U100 Universal Remote User Manual. Page 1. Page 2. Page 1 ... TheSanyo Universal Remote Control features large glow-in-. the-dark basic .
Nov 01, 2015 | Philips Televison & Video
SENTO SEN450 REMOTE CONTROL
Programming procedure is too much to type in here, and is not practical. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 18, 2013 | Televison & Video
Need sanyo universal remote code to add a ge vcr
This remote control have no setup codes for GE VCR.
Oct 26, 2012 | Televison & Video
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 25, 2010 | Sansui Televison & Video
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
Sanyo dvd/vcr combo
Your universal remote would have seperate selection buttons for VCR and DVD. If you don't have a VCR button, use AUX. Try programming each function seperately - DVD code for your manufactirer on the DVD button and VCR code for your manufacturer on the VCR button.
Sep 12, 2009 | Sanyo DVW-7100A DVD Player/VCR
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
