Question about Leica Pradovit D-1200
Do you know where I can get a daylight viewing box/attachment for my Leica Pradovit P300 IR slide projector; I saw a V design one, years ago, where you directed the projector inside and it displayed the image on a screen on the outside, another one I saw was an attachment for the projector which projected the image onto.a ground glass screen.
How to view slides without a projector
Slides can be viewed on a "light box" (a box with flourescent light source and a piece of white, translucent plexiglass on the top). you can lay the slides out on the light box & view them with your eye or with a magnifying device. Also, to view slides one at a time, Kodak marketed a hand-held Slide Viewer. I believe you can still buy one of them from Vine Valley Imaging
( www.vinevalleyimaging.com )
Good Luck !! Jim
Feb 15, 2014 | Kodak Office Equipment & Supplies
Slide projector help from Rollei- GmbH
What is exactly the projector make and model?
Jul 19, 2008 | Rolleiflex 3001 35mm SLR Camera
The slides appear to be dropping to far down so when viewed you see the top of slide (cardboard) and top half of picture- thi swas given to me used and I dont have a book - it is 300AF
Try using a full thickness plastic slide mount. Some card slides are so thin that they miss the slide support when being dropped down from the magazine. Some magazines are designed specifically for card mounted slides whilst other are for glass mounted slides. Types shouldn't be mixed for correct and consistent operation.
Feb 14, 2011 | Elmo Projectors Omnigraphic 301 Slide...
I have an old Kodak Caromate 3300 slide projector. Can I get a manual for this? I cant get it working properly, ie carousel will not move forward and slide cannot be viewed.
Is it a Kodak AudioViewer or a Caramate 3300?? hard to tell from the problem description.
If it is a Kodak branded unit, I know Kodak doesn't have the manuals any more, so my advice is to contact a factory-trained service dealer to see if they still have a service manual!
If it is Caramate branded, I'm really not sure where to send you. There were subtle design differences between the 2 brands!!
Good Luck !!
Feb 04, 2011 | Kodak AV210P 80 Slides Rotary Carousel...
I do not know how to make a cootie catcher. Can you make a page that will show me how to make a cootie catcher?
In all my years in the Slide Projector business, this is a new one. What exactly does a "cootie catcher" do?? Is it a filter? I have designed & supervised installation of projectors in some pretty high-tech areas, but never designed a "filter" for one. This is because the air that is exhausted from a projector is the air taken into that projector. So if the environment is clean, then the need for additional filtering of the exhaust air is not only unneeded, but the air flow restriction could damage the thermal fuses within the projector.
Oct 25, 2010 | Office Equipment & Supplies
Kodak 410 Projector/Viewer - no lite through projector or viewer
These projectors were designed & made by Telex for Kodak.
If the screen stays black when you push a slide down into the "gate" (in either viewer or projector mode), then the trip mechanism that opens the shutters when a slide is detected has a problem. It could be an adjustment, a broken or out of position spring or hardened lubrication.
There is no good way to proceed unless you are trained in the service of these projectors. Contact a factory-trained repair dealer. Happy New Year!
Nov 16, 2009 | Kodak Open Box BC-4601 Slide Projector
LCD monitor problem
The LCD works by allowing light to pass through it. From your description, the LCD is working but has no light behind it. This could be a connection problem or a failure of a component. If you are comfortable opening up the unit, look for a connector that is not fully seated. Otherwise, the camera will require service to locate the defective part.
Dan
Aug 28, 2008 | Leica C-Lux 1 Digital Camera
Unable to switch off projector with remote (Infocus SP4805)
A bit unusual for the projector to stop responding to the remote. Usually it follows when someone has opened the projector, they forgot to reconnect the controls from the case top which also includes the IR receiver. If it isn't that, it could be a broken IR pc board or bad connection. I've seen that.
The worst case is that the IR controller on the main board has failed and if that's the case, you'll have to live with it as the cost of a new board is very high.
Mar 13, 2008 | InFocus ScreenPlay 4805 Multimedia...
Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Feb 04, 2007 | Epson Perfection 1250 Photo Flatbed...
Sync via IR
There are a number of things to check: * You should first make sure that the PC that you are synchronizing with has an IR port. * If you have Palm software loaded, you should disable it. * If your PC has an IR port, then you should verify that the Microsoft ActiveSync software settings are correct. To do this you open the Microsoft ActiveSync window on your desktop and go to File --> Connection Settings and verify that the box that allows infrared connection is checked and the IRDA is selected. * Change the angle of the unit and make sure that there is nothing interfering with your signal. * Try removing the LCD protection cover.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Leica Pradovit D-1200 Logo
Top Leica Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Leica Office Equipment and Supply Expert? Answer questions, earn points and help others
