Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
52 INCH sharp aquos lcd REMOTE NOT WORKING
The volume can be changed with the remote...but volume bar does not show up....also tried pressing the menu button ..but it does not display any menu....
When yo upress the view mode, cannot see the mode options....and same with input......
  • heather862 Mar 21, 2009
    I have the same problem! There is also a yellow bar on the right hand corner where the input used ot be.
Make sure your remote lock is set to off.
Posted on Apr 22, 2009
  • Purchase5 Sep 14, 2011
    i had the same problem
    here is how you fix it
    on the top of your remote press the (dvd/vcr) button in lieu of the audio- for some reason that audio button puts a lock on the volume
Sound is pinned at 100% output. Remote nor physical buttons on device are working.
If any of the buttons on the remote or tv work, then try going into the menu and turning the sound down manually.
Jan 08, 2017 | Televison & Video
Sharp lcd tv. Grn lite flashing, reset by unplug, vol + ch - , plug in. Tv came back on, after few mins screen goes blk, have sound. turn off and on picture back for few minutes, goes blk, snd ok.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 07, 2017 | Sharp Televison & Video
I've tried to set up a Bose remote to my TV and B Ray player. I can get the programme change, menu and the channel guide working but not the volume + or - .I've tried other codes as instructed.
Jan 06, 2017 | Bose Televison & Video
Toshiba mv19m4..can i get to the menu without a remote? Want to adjust brightness..
YES THER WIIL BE A BUTTON THAT SAYS MENU DOWN BELOW AND THERE YOU CAN ADJSUT THE BRIGHTNESS CONTRAST SHARPNESS AND SOMETIMES DENSITY OF THE SCREEN INCLUDING THE COLOR
Dec 04, 2016 | Toshiba MV19M4 19 in. TV/VCR Combo
Devant ER 31951D remote
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Aug 23, 2013 | Coby TF-TV3217 32 in. LCD TV
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
Comcast remote code for 42in sharp aquos lcd
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
Dec 14, 2007 | Televison & Video
TV just flashes different colors
You have entered a diagnostic colour test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button. Problem resolved
Jun 25, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
1,231 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
