Question about Timex T42361 Outdoor Chronograph Alarm Watch for Men
Change the battery
How do i get the back cover off
  • Timex Master
  • 18,424 Answers
There are two types of back /snap on and screw on this link below will help you
http://www.watch-batteries.com/Changing_a_battery.htm
Posted on Jan 20, 2013
Needs batteries lionel collectable train watch need user guide and battery size
The Lionel Collectable Train Watch has 3 batteries in it. Two are for the whistle and one for the watch. All of them are V377 or 377 disk batteries. Gently pop off the back cover as most watches come off the same way. The battery by itself toward the middle is the train timepiece watch battery and is installed with the + side up toward you. The two batteries toward the edge are the whistle batteries, and you have to be very careful in changing them. Thee us a rotating contact that is plastic coated, over the batteries. NOTE: THE BATTERIES ARE NOT BOTH IN THE SAME DIRECTION. ONE IS UP AND ONE IS DOWN. (LOOK VERY CAREFULLY FOR A + AND - SIGN ON RIGHT NEXT TO EACH BATTERY.) For this reason, it is recommended to only change ONE battery at a time, so you will not get them mixed up. Gently spin the contact one direction, and one of the batteries will be clear and come out. Change that battery. Now rotate the contact back to the original position over both batteries, and continue rotating in that direction until the second battery is clear and can be removed. Change that battery. Now you can confirm that you still have one battery up and one down. Rotate the contact back to its original position, centering it on each battery. This contact has a layer of plastic material covering it on top so that it will not contact the watch case. If this plastic coating is damaged, it can damage the watch. If it is damaged, you might put a small piece of tape over the contact, to prevent other damage. NOTE that close to the edge of the watch is a very, very small spring sticking up. Make sure that spring is still vertical, as it is very delicate and can be damaged easily. That spring as well as the metal arm sticking up are part of the speaker circuit and must be in their place when the cover is replaced, as the speaker is in the cover. Now gently replace the cover until it snaps down. You will see the train moving around the dial and you can push the button and hear the whistle. Incorrect changing of these batteries by persons in jewelers departments of stores like Walmart and Target, have damaged more of these watches than you would like to believe. Hope this helps. (By the way, I do not have a brochure for the watch at this time.)
May 27, 2011 | Watches
How do you remove cover to change battery on kc 2342 watch
watches. Remove the back cover off the watch to reveal the battery. There are a very large range of batteries for watches. Remove the battery with non metallic tweezers or a sharp no metallic point. ...">watches. Remove the back cover off the watch to reveal the battery. There are a very large range of batteries for watches. Remove ...
Mar 10, 2011 | Watches
Need to open. coleman 40-334 watch not sure if the back is threaded
mcdevito75 here, If the back screws down, you"ll see a series of square holes around the edge of the back cover, in this case you"ll need a special tool called a case back remover tool to un-screw the back cover. If there are no square holes on the back cover, most likely it"s a press type back cover and some of these cavers are very hard to get back on wothout another tool called a case back press tool, these mentioned tools are available on ebay, but, with just a battery replacement, the time and tools you may need the cost is more than a watch repair shop would charge you. Best Bet, look for a small watch repair shop in your area for this once a year or even longer battery change.
Feb 11, 2011 | Watches
I want to change out batteries
1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
THANK YOU FOR VISITING FIXYA
Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
Fossil ch2360 can not figuare out how to get to the battery
mcdevito75 here, Most Fossil Watches have a press fit back cover. First locate ant tab, or indentation that is on the back cover linning up with the case itself, Carefully use a steak knife under that tab or in the indentation, slot in the cover abd pry up. From there you may need a jewlers screwdriver to loosen the battery hold down plate to remove the battery. BEST BET, look for a small watch repair shop in your area to change the battery.
Jul 31, 2010 | Fossil Watches
HOW TO CHANGE BATTERY
mcdevito75 here, Depending on your watch itself, Basically you"d remove the back cover, then release any hold down linkages on the battery, then replace the battery, hold down linkages and cover. The BEST BET is to look for a small watch repair shop in your area for this battery replacement as it may take special jewelers screwdrivers to change the battery.
Jul 10, 2010 | Armitron 0501643FA Wrist Watch
How to change the battery
the metal cover will be sliding and if you will slide it left or right battery should come out.
Thanks
Nov 25, 2009 | Kenneth Cole KC2315 watch
How do i change the battery in a timex wr 30 m watch
remove back cover plate- inside you will need a jewlers screw driver- install new batery in reverse. install screw- and snap cover back in place.Make sure battery is new.
Dec 31, 2008 | Timex 27191 Wristwatch
Removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
Jan 13, 2008 | Casio MQ24-7B2 Wrist Watch
Timex T42361 Outdoor Chronograph Alarm Watch for Men Logo
54 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
