Question about Yamaha RX-V540 Receiver
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos. I have had it since new. Yamaha Rx-V547
    Problem Solver:
  • 17 Answers
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Posted on Jan 21, 2013
techman
  • 3130 Answers
SOURCE: Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Posted on Sep 22, 2006
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
This solution helps! I got this unit from a friend and there was no sound from the left channel, and after playing with the input knob, there was sound.
I sprayed alot of electronic cleaner and it worked like magic.
the unit is now in full working mode.
Posted on Mar 22, 2010
SOURCE: Yamaha RX-V365 Receiver, Yamaha NS-AP2600S(BL) Speakers
I have the same issue. I took the speaker apart and tested with a meter and both the mid and tweater were wide open, in short blow out. Not sure what caused this but the speaker needs to be replaced.
Posted on Jan 14, 2011
BElectric
  • 1140 Answers
SOURCE: No sound from left channel
Hello Danza,
It's possible you've blown the left channel, but the fact that you have no audio in the left channel from both A and B speakers makes me wonder whether the balance control has been accidentally rotated to the right.
There is a rotary control on the front of the receiver for BALANCE. This should be in the 0 position, i.e. top dead centre. If it's been moved to the right, you wont get audio from the left channel from either A or B speakers.
Please check your balance control first then let me know if you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Regards.
BElectric
Posted on Apr 03, 2011
dunnbiker
  • 8546 Answers
SOURCE: Yamaha Rx-V367 Subwoofer not working,
Have you looked at the manual?
The NEW thing doesn't work.
Does the subwoofer work for setup? That would certify the hardware and speaker definitions are ok.
The PC has the responsibility for defining and sending out something between headphone and full-blown 7.1 though the HDMI. Check your PC sound controls and the "Information on HDMI" section of the manual.
For the radio mode, probably the only analog stereo source you have, read up on the STRAIGHT decoding mode and Sound Field programs.
Posted on May 08, 2011
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Amp wont work
Hi I have a Yamaha DSP 3090 Amp my right main Chanel is not working Amp goes off when i try to put the power on i think it goes on protction mode?after trying for 5to10 times it comes on, test mode all chanels work well not sure whats wrong ? can anyone slove my problem
Jan 02, 2010 | Audio Players & Recorders
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
Sound problem with home theater speakers
Change both left & right TDA7275 IC
Change all the 1uf 50v capacitors related to the IC,s
Thank you very much
contact me at meganetsl@yahoo.com
thank you again
M.Fateh Almunajed
Jul 28, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
Harman-kardon citation 7.1
Go to diyAudio.com and try asking there....
Jan 10, 2009 | Harman Kardon Audio Players & Recorders
No sound from Front Speaker
take amp to a workbench, have a test speaker in hand, touch the speaker wires to each channel to see if all channels work. take each speaker to the amp and temporarily hook one at a time to see if any speaker is bad. if you eliminate the hardware, you know it's the wires in between.
Mar 02, 2007 | Mission 700 Main / Stereo Speaker
Yamaha RX-V540 Receiver Logo
205 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
