Question about HP 417136-001 PAVILLION DV8000 MOTHERBOARD
How much ram can I install in my computer - HP 417136-001 PAVILLION DV8000 MOTHERBOARD
    Sergeant:
  • 236 Answers
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
I have problems with the ram in my laptop what can i do? how can i find out if its a hardware problem or software
To check if you have a RAM problem, go into the BIOS and check the amount of RAM installed, does this match the total amount of RAM installed, if the RAM in the BIOS does not match the total amount of RAM in the RAM modules then you may a faulty RAM module or an incompatible RAM module.
If it is a software problem, a program may require more RAM than is installed on your computer. The software instructions will recommend the amount of RAM your computer should be installed with.
Apr 11, 2012 | Acer Aspire 5336-2283 Notebook
My T5212 computer doesn't see the 1gb of ram, why?
The RAM mybe be faulty or incompatible/wrong type for your computer.
Check the specification of the RAM that is required for your computer.
If you want to install 2 off 512 Mb RAM make sure the are the same make and model.
Mar 09, 2012 | eMachines T5212 PC Desktop
My computer does not work with two 2GB RAMs
I think, one, out of the two is defected. Make pair with other memory or try changing the slots and vice versa. And for dual channel memory mode, you must installed two identical memory. I mean sizes and makes may different, but bandwidth should be identical to each other.
Jul 30, 2010 | Intel DG31PR Motherboard
Pc doesn't start properly, and displays a 1 & 3 on the front panel
Memory modules are detected, but a memory configuration or compatibility error exists.
May 11, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
I want to upgrade the standard 512mb RAM to 2GB. once installed do I just restart the computer or do I need to do something to allow the computer to recognize the new RAM?
You should be fine to just turn the computer on straight away as soon as you have installed your new RAM. The computer will recognize the new upgrade straight away provided you have got memory that is compatible with the desktop computer.
When you upgrade the RAM take the old RAM out and make sure your new RAM runs at the same speed as your old RAM.
From what i can remember the maximum RAM speed that an HP pavilion supports is 400MHz although it could well be 333MHz.
The RAM that's installed in the desktop at this moment in time will have the speed on it so you check with that.
Regards.
Jan 25, 2010 | HP Pavilion a450n PC Desktop
I have a computer with an intel al440lx motherboard, pentium 2 processor w/mmx, ATI rage 3d graphics card ,creative sound blaster pci sound card, 7GB quantum HDD and 40GB seagate HDD and 1.024 GB SDRAM...
This is not a software problem. The problem lies in the motherboard.
The motherboard which you are using is an AL440LX motherboard which supports a maximum of 384MB of RAM. The computer will not recognize any more RAM. In order to use 384MB, you will have to add a 128MB RAM along with the 256MB already present and not any more !!
This is the solution !!
Jul 30, 2009 | Computers & Internet
Windows won't see all of my 4GB of RAM but BIOS does! Why?
Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
Dec 18, 2008 | Dell PowerEdge 1600SC Server
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Apparent conflict between my wireless adapter and RAM
have you tried looking for an updated bios version for your motherboard?
Jan 05, 2008 | Computers & Internet
HP 417136-001 PAVILLION DV8000 MOTHERBOARD Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
