Question about Gigabyte GA-8ID533 Motherboard
Can't get into BIOS to turn on keyboard function
Gigabyte Pentium 4 Titan Series GA-8ID533 1.1, AWARD BIOS. I was attempting to fix a problem and some how the keyboard function would not work after I changed some BIOS settings. So when I start up puter it repeated goes thru the post test and I can not stop it because keyboard does not work. Help...anybody? I can't even press Ecs key or any F keys. Frequency is 1.7GHz (100x17.0), memory size 128mb and I'm running Win XP Professional, 32. I don't have a rescue disc and don't know how to make one. I do have access to internet with my other puter...and it's running Win XP Professional...so if someone could help me I would greatly appreciate it.
Thanks Msjay160
  • 2 more comments
  • msjay160 Jan 26, 2009
    PS/2...I'm using the keyboard right now on this puter and works fine.
  • msjay160 Jan 27, 2009
    Hey, I didn't think of that. I have BIOS flash procedures and the User Manual GA-8ID533 for the motherboard. I'll try it and get back to you. Thanks
    Oh yea I did the battery and then I bought a new lithum battery and no results. I know this problem is something I did. I really appreciate the help.
  • Azz
    Azz May 11, 2010
    Hi, are you using a USB keyboard or a PS/2 keyboard?
    Are you certain its not the keyboard, have you tried another one?
  • 55 Answers
I would suggest either opening up your pc and reseting the bios, either by removing the the flat battery for a couple of mins, or if that doesn't work there may be a jumper or switch you can change that does this. I searched online but was unable to find any instructions for you.
You can either contact Gigabyte direct for instructions or try flashing your bios, both of which you can do from here:-
http://www.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=1398
Take note of the warnings when flashing the bios.
Posted on Jan 26, 2009
  • Azz
    Azz Jan 27, 2009
    No worries, let me know how you get on.
Is there any upgrade for my Bios? Bios type: Award
Why don't you look at the support section of the Gigabyte website? That is where you will need to go to download it anyway.
Sep 16, 2013 | Computers & Internet
What CPU is compatible with the motherboard GIGABYTE GA-065P-DS3?
The following CPUs are compatible:
Core 2 Extreme Core 2 Quad Core 2 Duo Pentium Extreme Edition Pentium D Pentium 4 Extreme Pentium 4 Celeron 400 series Celeron D
You may need to update your BIOS to get full support for all of these CPUs. Literally dozens of CPUs are supported by your motherboard.
Feb 22, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Cannot find virtual in BIOS. Award BIOS F2
Gigabyte mother board BIOS set hot key Delete you keyboard
Mar 04, 2010 | Gigabyte GA-EX58-UD3R Motherboard
Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
P4 2.66GHz 533FSB Problem on Gigabyte GA-8ID533
well if the board support till 400FSb then the 533FSb CPU will not work with the board did you check the website and he board manual that says it support upto 533 bus?
Nov 08, 2008 | Gigabyte GA-8ID533 Motherboard
BIOS problem!!
Why do you want to overclock it? Have you changed the cooling system? Overclocking might fry your processor if the cooling cannot keep up with the heat. Does your motherboard support overclocking? The option might be locked. There might be a jumper on the board that you have to mingle in order to enable that setting.
Sep 21, 2008 | Computers & Internet
Audio/sound
For the Vista compatible sound drivers of a Realtek AC'97 as used in a Gigabyte GA-8ID533, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Gigabyte GA-8ST800 Motherboard
Motherboard does not startup
Please remove the CMOS battery & reinstall it after 15 minutes.
Jun 28, 2008 | Gigabyte GA-6BX7 Motherboard
Gigabyte GA-8ID533 Motherboard Logo
612 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
