Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Noisey pump a rattling noise is heard during drainage when the pump is running and all water is not pumped out of tub. A second cancel/drain cycle seems to empty the tub, but pump makes the same rattling noise. Do I need a new pump?
  • 38 Answers
Take the drain pump apart and look for debris, or broken pump impeller. Remove the lower spray arm and filter assembly, check for debris in the sump and check the drain check vavle to make sure it is sealing properly. While in there make sure the food disposer blade are not clogges with debris.
Posted on Feb 23, 2009
Why does it quit randomly during cycle?
If you cleared the drain pump trap of obstructions, and the pump still runs fine(without rattling from a loose or damaged impeller) then most likely you have fixed the problem. The washer will not spin if it can't drain--and if the water is draining too slowly, it will time out and give an error code for "slow drain". For any items such as bras, underwear, socks, baby socks, stockings, pantyhose, etc, use a netted clothing bag with a zipper to prevent those types of things from getting pulled in-between the basket and tub and then making it to the drain pump trap. These things are notorious for clogging pumps on front load and top load HE washers!!
Aug 02, 2015 | GE Washing Machines
Top load washer about 8 years old- Problem 1 = during the finial rinse/spin the tub will not fulling drain and leaves clothes very wet...had a service call replaced the pump, however stills does not drain...
most likely its the electronic board, easy to change. if you can use a second hand one out of a known working machine- see how that goes- it will probably cure the noise problem
Sep 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Displays f 02
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
Included is a follow-on link that explains how to access and check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher not draining and making a noise
Ok, normally, when you hear abnormal noises and the draining has stopped, this will point to the pump/motor assembly. this assembly , basically, runs together in unison. the pump/motor are as one and if the motor is malfunctioning, the pump will not drain properly. this noise is coming from the pump housing. There are many parts that are located in this housing and one fragile part that can cause issues is the Impeller. this piece provides the pump action that moves the water during drainage. If the sleeve that connects to the Impeller becomes stripped, the motor drive bolt will simple spin freely, causing this noise and no drainage. The motors fine but, you will have to replace the pump assembly in order for this noise to stop and the normal draining cycle to return. just to be safe, check all the drainage hoses as well.
please rate and god bless:)
Apr 01, 2009 | Frigidaire Dishwashers
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
293 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
