Question about Pentax Optio E30 Digital Camera
Memory Card Full
I have a brand new pentax E30 and every time i turn it on it says "memory card full". if i press the image folder button it says "no image folder could be created". then i eject the memory card, take it out, put it back in, turn it back on, and it works?? please helP!
    Sniper:
  • 60 Answers
Hi, 1.make sure your memory card is not damaged and also formatted by camera ,this is because if card is damaged or not recognized the camera stores image in internal memory which may be full by this time. 2.backup all your data and delete all from internal memory also format the card and try using it. All the best my friend regards sreejith
Posted on Jul 17, 2007
  • sreejith sree
    sreejith sree Jul 17, 2007
    hi,
    please try reducing the image quality (refer page 106)on the below link to make sure camera works fine. http://www.pentaximaging.com/files/produ...
    regards
    sreejith
I have a Pentax Kx and recently bought an 8Gb memory card. However I get a lot of blank images with the error message 'image cannot be displayed' especially if I use the continuous shooting mode....
Dear,
First of all you need to confirm that what kind of memory card your are using. The officially recommended type and brands are here
Toshiba *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
Panasonic *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
SanDisk *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
rather than these might be problematic or not compatible...
Check this first
Best of luck!
Jul 10, 2011 | Pentax Cameras
Memory card is full and when I plug in the USB cord and turn on the camera I get a message that my device is not connected or is busy, or that it contains no pictures!!
Causes of memory card corruption
  • Turning off a camera before an image is completely written to the memory card.
  • Removing the memory card from a camera while an image is being written to the card.
  • Removing the card from a memory card reader while files are still being transferred to a computer.
  • Batteries conking out as files are being transfered directly from the camera to a computer. Note: always make sure you have fully charged batteries before transferring images.
  • Removing the card from a card reader while folders and files from the card are open on a computer.
  • Opening, deleting, renaming or moving files on the card while its contents are open on a computer.
  • Using a memory card which has not been formatted in the camera. Use the delete/erase function when needed, however a card should be regularly formatted.
  • Formatting a card in a computer instead of the camera.
  • Inserting a second memory card into a card reader before closing and removing the first when viewing images on the card from a computer.
  • Taking photos when camera batteries are nearly empty.
  • Taking photos too rapidly so the camera can not complete writing one image before starting the next.
  • Continually shooting and deleting, shooting and deleting images when the card is full.
  • Letting a memory card get too full before downloading the images to a computer or storage device. Cards that are too full may overwrite the card headers.
  • Using a memory card from one camera in a different camera without formatting it in the new camera first.
Feb 28, 2008 | Cameras
The memory card in my pentax optio 60 is full. Can I record over it and if so how The memory card in my pentax optio 60 is full can i recoed over the top of it and if so how David
Certainly. If you're sure you've copied all the pictures you want to your computer, simply format the card to wipe it clean. Rotate the mode dial to the screwdriver-and-wrench position and turn the camera on. Use cursor-down to select "Format" and press the OK button. The instructions are in the "Formatting an SD Memory Card or Internal Memory" section of the manual (page 22 in my copy).
Memory cards should be formatted each time you finish transferring your pictures to your computer. FixYa is full of people asking how to retrieve pictures from cards that haven't been formatted regularly.
Apr 23, 2011 | Cameras
Internal Memory on Camera wont allow format
You usually have to take out the SD card, close the door and then delete images in camera in the normal way (press delete button in play mode, when confirmation dialogue appears, press delete button again, select >delete all< and press OK). Most cameras default to the memory card when one is inserted, that's why you have to take it out to delete data from the internal memory.
Hope that helps
Aug 01, 2010 | Pentax Optio M60 Digital Camera
Memory card is always full even though it is new
Hi, The solution is to format the memory card or initialize the memory card. Note formatting the memory card will delete all the pictures or data stored. Formatting memory card
1. Press the MENU button in any mode.
2. Move the 5-way scroll button to the right and press the confirm button to enter the SETUP menu.
3. Move the 5-way scroll button down and enter the FORMAT menu. Press the confirm button and the "Format?" dialog box appears. Select "Yes" to start formatting. Select "No" to cancel.
Apr 12, 2010 | DXG Technology DXG-409 Digital Camera
Error message Built in memory full. Also won't read memory card.
You need to format the internal memory with no card in the camera. Then, you need to format the memory card in the camera.
Feb 17, 2010 | Pentax Optio S5i Digital Camera
Can't view image, and "built in memory full" is displayed
Connect your camera to a computer and offload all the pictures. Then, format the camera's internal memory. If you have a memory card, it's best to use that and only use the internal memory when the card fills up.
Sep 24, 2009 | Pentax Optio E30 Digital Camera
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Memory Card reads full when empty ? Pentax kd 200
Ok, first you mak have a fake card. The capacity of the card is coded into the card and fake cards often lie about their capacity.
If you know the card is not fake, then reformatting the card should clear it. You can do this in the camera. (Check the manual for instructions.) Or if you have an SD card reader that plugs into the USB port of your PC, you can download a SD card formatter for free. (The official SD card standard site has these.)
Dec 24, 2008 | Pentax K100D Digital Camera
Internal memory card full
You are using built in internal memory (11Mb).
One of these must help:
*Check memory card.
*Check picture saving settings.
*Reset to factory defaults.
User Manual
Feb 13, 2008 | Pentax Optio E30 Digital Camera
Pentax Optio E30 Digital Camera Logo
147 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Vuk B
Damen Wong
Damen Wong
Are you a Pentax Camera Expert? Answer questions, earn points and help others
