Question about Toshiba (K000006610) for Satellite P25 Series Motherboard
Laptop will only charge when sidewards pressuse is put on connection at back of laptop
  • Toshiba Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Jan 20, 2013
What creates crank case back pressure?
There is a PCV valve that relieves that pressure and puts the vented air into the intake for emissions control
Apr 15, 2016 | Cars & Trucks
My screen as gone sidewards how do i change it back
Depending on which side of the screen is on you would hold the CTRL and ALT keys and at the same time press one of the arrow keys....up or down or left or right.
B1L
Aug 10, 2014 | Computers & Internet
My laptop screen as gone sidewards how do i change it back
Try changing the screen setting in control panel.
Where is the fuel pressuse regualator location
Under the hood, top of engine drivers side about half way back front front of engine.
Aug 24, 2011 | 2004 Cadillac Escalade
My cafe comes out sidewards and not by the two nozzls,. everything gets messy and I can not collect the cafe into a cup
HI
Your spout is getting clogged with residule coffee. There is a screw pin behind the spout that you can loosen and remove the spout to clean. There will be a long tube attached to the spout dispenser.
When you put it back in the tube slips on the brew units outlet before you tighten the screw down.
Jan 27, 2011 | Saeco Stratos Coffee Maker, Espresso...
All my window icons and task have turned sidewards
Welcome to FixYa, the best online community for tech related issues.
Please elaborate your problem providing us with more details
Thanks for using FixYa.
Jan 19, 2011 | Samsung N13013B Netbook
My screen is turned sideways on my latitude e5510 how can I fix it?
The screen turned to the sidewards.. This issue can be fixed..
Try these steps
Press and hold the keys Control+ALT and then use the arrow keys and change the screen view.. The issue can be certainly fixed
Dec 04, 2010 | Dell Latitude E5510 156 LED Notebook PC...
Laptop keys sticking
Try the following:
1. You need to clean up your laptop keys by a soft paintbrush or vacuum cleaner. Try removing the keys by gently pulling it sidewards.
2. Run virus update and scanning. Probably there is a VIRUS on your system
Thanks. Cheers!
Apr 20, 2010 | Dell Studio 15 Laptop
I have an acer 5735, the battery won't charge, sometimes it states plugged in charging, sometimes plugged in not charging, and sometimes fully charged, but in all cases it is not charged at all?
Hello
you can try this things
1st option
Remove your battery and check the pins if are bended or missing
2nd option
1- remove your battery
2- directly connect AC adapter
3- restart or on your laptop
4- after loading windows, put the battery
3rd option
Take battery out and use pencil erases to gently clean the contacts. Also clean contacts on laptop battery box.
Sometimes the contacts oxidize.
Then put back in and see if it charges.
if nothing of this worked,you will need a new battery
Jan 13, 2010 | Acer Aspire 5580 Notebook
Not charging
I found out how to solve this problem...first power down your computer. Then take out the battery, remove the power supply, and then hold down the power button for 30 secs. Put the power supply in only (not the battery). Start your computer after everything is done loading up put the battery back in. Give it a min. and then you should be able to roll your cursor over the battery life indicator in the lower right corner of you computer and is should say charging. I have found that other people have had this problem and it has worked for myself and for them.
Aug 26, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
