Question about Acer Aspire L100 PC Desktop
No desktop view
I own a Acer L100 and when I hook up everything and I turn on the tower, the moden says no signal and everything i hooked up right, what could be the problem?
  • 3,940 Answers
The L100 series has a bad reputation for overheating. I worked on a friends and had to reseat the heatsink for the processor with new thremal paste to keep it running
Posted on Jan 26, 2009
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My acer m460 computer had a glitch in the middle of a commercial on a show I was watching on hulu.( was like a cd skipping) so I. Pushed control alt delete and nothing happend so I manuly turned off the...
    Could be power supply problem.
    Do any lights on the front of the pc come on?
    Does the motherboard standby light come on when the power is swiched on?
    Any fans come on?
    Try swapping out the power supply if you have a spare.
    Good luck and comment back if this was helpful or if you need further assistance.
    Feb 03, 2011 | Acer Veriton M460 Micro Tower Core 2 DUO...
    We are getting a No Signal on our monitor,
    it should be motherboard problem.
    try to check it nearby service centers
    are you able to hear any beep sounds
    pp
    Nov 21, 2009 | Acer Aspire L100 PC Desktop
    I have the acer 8.9 inch with a built intnet wireless care. The one that connectst to the internet throutht the air waves Just as if it needs no router or modem, but i cannot connect. What do i do
    It does need a Router and Modem. Every computer does. Even if you bought the new Verizon mini pc, it needs the towers signal since that is the router. Wireless just means that you don't have to drag a wire from the computer to the router. You need a wireless router that will attach to the modem for this to work. Otherwise the signal from the computer just goes into the air into nowhere. If you go to stores that have "hot spots" or "wifi" and use your computer, that just means that they have a router that you're signal is hooking up to.
    Jun 09, 2009 | Acer Aspire L100 PC Desktop
    I have a Lexmark 5150 all in one.I recently hooked up to broadband.I cannot use the fax now. It says no communciation. How do I get my fax machine to work again? The printer and scanner work fine.Do I have...
    Hi Brenda,
    Your All In One wants a phone line hooked directly to it. It won't fax without a "POTS" line directly hooked to it. POTS stands for "Plain Old Telephone Service" which is the line with good old dial tone on it.
    Dec 17, 2008 | Lexmark Computers & Internet
    Acer L100
    Its a nosiy solution but in the BIOS, switch off the smart fan. The fan will speed up from 2800rpm to aroun 7200rpm and the tower will not overheat.
    Aug 04, 2008 | Acer Aspire L100 PC Desktop
    Desktop pc
    could be all manner of things, from just the graphics card, to the PSU or even the CPU, itself, I would start trying to test the graphics card (may just need reseating) and then test the PSU, then take it from there
    Oct 07, 2007 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    100 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
