Question about Indesit WA 115 Front Load Washer
Gorenje washer wa 101 user manual - Indesit WA 115 Front Load Washer
How do reset for washing machine
I do not see a way to do a reset on this unit. This is the manual and shows what things you can try. Manuals Gorenje UK
Sep 30, 2014 | Gorenje W7543LR Red 600 mm Washer Front...
Gorenje wa 72145 my son put washing up liquard in last night and the bubbles over flowed so i stoped the washer and empyed it. This morning iv gone to use it and f2 error comes up and wont work
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Jun 09, 2014 | Washing Machines
Washing machines
/manuals/_washing_machines/gorenje.html
you can get the item you need here good luck
Jan 12, 2014 | Washing Machines
I need user manual for washing machine GORENJE WA 50100. Thanks.
Thanks for saying thanks! So many 'demands' for manuals are as if they have been posted to a manufacture's site rather than to the 'public' on FixYa ;-0)
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 25, 2011 | Washing Machines
Please send me the user guide for Gorenje WA 61101, via email. Especially the programmes and the use of all buttons. Urgent!
Hi and thanks for choosing FixYa, I am Kelly
I understand why you came to use in search of your manual. It was quite a task locating a manual for you and the WA61101 does not come up anywhere. I did find a manual I think you can use. This is NOT the exact manual but the WA6xxxx series appear to all use the same instructions. This manual is under the WA60125 model. Let me know if this does NOT work for you or if it does work for you. If it does not work for you I will search again. This search took about 1 hour.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Washing Machines
Gorenje washing machine wa 72145 washing clothes but doesnt spin keeps comimg up child lock
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | LG WM2301H Washer
Need Gorenje WA 64153 service manual
Look behind the control panel or inside the cabinet taped to the wall.
Sep 07, 2009 | Washing Machines
I need schematic diagram for gorenje wa 50050 washing machine
I find a schematic diagram on internet address www.masine.sigma-com.
Thank you for trying!
Jun 29, 2009 | Washing Machines
No manual for Gorenje front loading washer.
Here is a link to the Gorenje website, you can download the manuals from there which explain all the symbols. This link is for the WA50140 machine which I have, just click on the 'manuals' tab
http://www.gorenje.co.uk/laundry/washing_machines?c=161105
Jan 27, 2009 | Washing Machines
Open Questions:
See all Indesit WA 115 Front Load Washer Questions
Indesit WA 115 Front Load Washer Logo
188 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
