Question about Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver
No sound skyfi2 I can only get sound with the headphones, no sound when it's on regular
    Scholar:
  • 116 Answers
Do you have the FM Modulator settung turned ON? There is a seting in there somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
Speakers not working headphones
If your regular speakers are working, then your headphone jack is broken and must be replaced. If neither has sound, try reinstalling the sound card driver available from the laptop manufacturer's website.
Oct 16, 2013 | Acer Aspire 4530-5889 Notebook PC
Left ear does not work (very very weak sound)
try a regular cheap set of headphones on that device .If its the same ,then the audio device is the problem.Or try those sets of headphones on another audio device , computer,tv,cd or stereo receiver.If you are using any kind od adaptor inbetween those headphones and the audio device ,then check that..If they sound the same on any known good device..Then its possible they are bad ..let me know
Jan 03, 2008 | Shure E3C Consumer Headphones
No sound in headphones
Could be that your audio jack has material stuck in it or possibly the jack is bad.
Mar 07, 2013 | Motorola Mobility Electrify
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
Delphi skyfi2 Xm Radio Receiver car connection
Yes, you can buy an FM Direct adapter that will allow you to transmit directly to your car FM tuner, but if you have an older SkyFi2, the Fm transmitter is so strong, you can sit the radio on the floor and tune your car radio to your preset XM channel, like 107.1 FM and it will work great. Go into "Menu" and pick a channel that's not used locally.
Jul 12, 2010 | Delphi SKYFi2 SA10101 XM Radio Receiver
Mac book volume only works with headphones or speakers connected there is a red light coming from where headphones should be connected
It sounds as though you may have damaged your board. Is it under warranty did it get wet. The headphone jack port supports both regular headphones and optical line out. The optical is activated for some reason. Go into settings and check your settings for sound.
If you need help just email me.
Jan 29, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Delphi SKYFi2 won't work
I just had my dial pop out and pushed it back in, with limited use again. You may have cracked the circuit board. If so, I would buy another SkyFi2 from eBay, etc, so you can reuse all your accessories. IMO, the SkyFi2 is the BEST XM radio ever built in terms of features (until it hits concrete).
Mar 21, 2009 | Delphi SKYFi2 SA10101 XM Radio Receiver
Lost the user manual
go to google.com and type skyfi2 xm radio manual. you will find the manual there as a .pdf file.
Dec 23, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Dec 13, 2008 | Toshiba Satelite A10 Notebook
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver Logo
130 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
