Question about Nordic Track GX 4.5 Cycle
Just purchased a Nordic Track GX 4.5 bike. The resistance remains high and adjusting up/down has no effect. Is there a calibration that can be done on this machine?
Resistance on Nordic Track Gx 4.5 bike stuck on high.
5 Suggested Answers
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Posted on Jan 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Posted on Jun 14, 2010
ercupa190
  • 12223 Answers
SOURCE: nordic track cx 1055 elliptical
see the next video for help:
Posted on May 03, 2012
emissionwiz
  • 75822 Answers
SOURCE: Console of my nordic track audiorider r400 keeps beeping continuously.Buttons on it do not resppnd. There's no resistance developed when desired button is pushed.
It is likely the control board for the motor is burned out and needs to be replaced.
Posted on Oct 24, 2016
Why can we only peddle backwards. When we peddle forward, there is too much resistance.
Your resistance motor can be bad, the magnets are full expanded and stopping the forward movement.. You need a crank remover to take the body covers off to inspect the resistance motor.
Mar 01, 2015 | Nordic Track NordicTrack - GX 2.5
Nordic track 1000 works only on speeds 1 and 7
adjust the speed sensor, see the diagram attached. clean it and test it for open or faulty. Tight the connector very well.RUN the software calibration for easy diagnose, and fix it. God bless you3_22_2013_4_23_05_pm.gif3_22_2013_4_23_19_pm.gif
Mar 22, 2013 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack gx 5.0 pro will not turn on
Did you ever find a solution to the dashboard of your Nortictrack 5.0?
Jan 20, 2013 | Nordic Track NordicTrack GX 5.0 Pro...
I HAVE A NORDIC TRACK E 3500 WITH AN INCLINE PROBLEM WHERE BY IT DOSEN'T RESPOND TO THE REQUIRED LEVEL .I'VE TRIED TO RESET MANY TIMES WITH NO SUCCESS .IT SEEMS TO CHANGE THE ACTIONS ON...
1)Lube the shaft, gear from elevation motor see the picture
2) adjust the POT a little.
3) see the diagram attached.
4) RUN the software calibration go under the hood motor and see the instructions for troubleshooting, and fix it.
God bless you
Nov 11, 2012 | Nordic Track NordicTrack Professional...
Flashing Nordictrack R400 AudioRider Display
https://support.nordictrack.com/exercise-bike-support/
Apr 05, 2017 | Nordic Track NordicTrack GX 5.0 Pro...
How do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
Aug 01, 2010 | Nordic Track Nordictrack Exp 1000...
Nordic track commercial 1300 manual
Jun 12, 2010 | Nordic Track Exercise & Fitness
Replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
Mar 01, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordic Track GX 4.5 Cycle Logo
149 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
