Question about Acer Aspire Computers & Internet
Have an acer aspire 5536-5255 over heating and malware will not work...
I have been having tis issue with pc getting hot and shutting down, and the malware is not working right,,, i keep havingto factory reset. any clues as to what is going on and how to fix this would be most greatful ty
  • Acer Master
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Jan 20, 2013
Pattods
  • 116 Answers
SOURCE: full factory reset
If the PC came with a recovery disk, just simply start the computer with it in the disk drive and it will have the option to "start from scratch" or the like. It will take everything back to the way it was when you first bought it.
Now, some laptops do not come with recovery disks. In this case, you'll need a windows disk with the CD-key for that version. Start the computer with that disk in the drive and just follow the prompts. It will give you the option to upgrade or fix windows, or to install windows. Choose to install windows and format the C:\ drive when it asks you if you'd like to format. It will then erase everything on the hard disk by formatting and continue to install a fresh copy of windows.
Be forwarned.. Windows installs are like watching grass grow; be prepared to have at least an hour of time to do the job. If there's any specific questions you have about it, or even a worry or the like; please feel free to ask. :)
Posted on Sep 10, 2008
  • 65 Answers
SOURCE: Acer Aspire 5315 No Recovery Disk - Restart
yes you can use the recovery partition which should be built into the hard drive. press f2 on the bios screen and follow the on board instructions. this will return the laptop to its original factory state. Keep in mind that this is a destructive reinstall of windows and you will lose all data and programs.
make sure you do a recovery and NOT a system restore to earlier date.
hope this helps.
Posted on Dec 10, 2009
contratek
  • 83 Answers
SOURCE: pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Posted on Jan 21, 2010
    SpideRaY
    • 687 Answers
    SOURCE: my acer aspire 5735 randomly shutting down
    Try taking out your battery it might be shorting out just run your laptop from the adapter and see how long it lasts before it shuts down
    Posted on Feb 22, 2010
    GSPOT12
    • 75 Answers
    SOURCE: My acer aspire 5742z laptop
    Hi!
    Issues like this mostly caused by a program or simply a corrupted operating system updates. I would suggest we try restoring the laptop back in time when the issue is not yet present. We can achieve this by performing System Restore, if I'm not mistaken, this laptop has Windows 7. Please click on the Start button, then go to All Programs> Accessories> System Tools and then finally System Restore. Please select a date when the issue is not yet present. Then, please reboot the laptop.
    Hope this helps.
    Posted on Apr 17, 2011
    Power supply
    Your fan needs to work to cool the processor. Sounds like it is getting too hot and shutting down/restarting. Once it is cool, boot into the OS and check your event logs which should give an indication as to why but it does sound like a heat issue
    Mar 21, 2014 | Acer Aspire X3400 PC Desktop
    Aspire z5600 keeps turning off
    You could have an overheating issue. most computers get hot after a small period of time and that heat must be dissipated. To do this, the computer uses fans and heat sinks. These need to be cleaned of dust and dirt or they will clog and fail to remove heat from the system, forcing it to power down.
    Oct 02, 2012 | Acer Aspire Z5600 PC Desktop
    My acer aspire 5738g keeps shutting down when i'm
    Sorry you are having troule. It sounds as if it is getting hot and protecting itself. Games are very cpu intensive and this causes heat. The cheap fix is an under cooler. This is a cooler the laptop sits on. I have seen them at Best Buy for under $20
    Apr 07, 2010 | Acer Computers & Internet
    Acer Aspire one turning off right during load up
    It may not feel hot, but that doesn't necessarily mean it's not an overheating issue. Typically if the processor gets too hot, the computer shuts down to prevent the proc from frying. That's what this sounds like in this case. There are a few programs that can monitor your cpu temp (among other things), but in this case it doesn't seem like that will work for you. If it's under warranty, I'd recommend contacting Acer support and see about getting either a new laptop RMA'd to you, or whatever their procedure is to resolve potential systemboard issues. If not under warranty, I'd recommend having a professional check it out to chase down and resolve this.
    Aug 13, 2009 | Acer Aspire One Netbook 8.9" Notebook
    Laptop shuts down shortly after boot up
    this looks like heat issue...varify that the cpu fan is working.....apply heat sink cream on the cpu surface and the heat sink
    keep me posted
    May 13, 2009 | Acer Aspire One PC Notebook
    Acer aspire 5610-4654 keeps shutting down
    Did you noticed overheating (hot laptop areas, fans spinning like in crazy?)
    Can you start the laptop again just after it shuts down itself??
    Jan 18, 2009 | Acer Aspire 5610-4648 Notebook
    Possible overheating problem for Acer Aspire mini L100
    I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
    In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
    Sep 26, 2008 | Acer Aspire L100 PC Desktop
    My Acer Lappy turns off automatically!
    This could be a heat issue. Make sure that nothing ( eg dust) is blocking the air vents.
    Jan 11, 2008 | Acer Aspire 5630 Notebook
    Computers & Internet Logo
    89 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
