Question about John Deere Garden
John deere L108.drives for about 2 minutes mowing and stops.leave for about 15 mins and will go again.puffs of smoke when put under load
L108
    New Friend:
  • 3 Answers
Adjust the fuel/air adjustment screws on the carb until it runs properly.
Source: http://www.melbournesmowercentre.com.au/products/ride-on-mowers.php
Posted on Feb 18, 2013
    Sergeant:
  • 391 Answers
John:
The puffs of smoke when you put the machine under a load make me think that your carburetor is loading up and needs to be adjusted. Adjust the fuel/air adjustment screws on the carb until it runs properly.
Posted on Jan 20, 2013
SOURCE: john deere stx 46 wont move just howls
Stx46 Kohler engine. Remove float bowl, check float operation. These floats are plastic, preset to obtain proper float level from the factory. The needle should move freely up and down in its seat. Overtightening the bolt that holds the float bowl on indents the bottom and thereby changes the fuel volume. Straighten the float bowl or buy a new one. This should help. Very frustrating; right.
Posted on May 03, 2012
SOURCE: My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Posted on Dec 31, 2010
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Posted on Nov 13, 2009
Motor froze up while mowing grass, did not hit any objects. John Deere Model 14PZ Pull rope only moves about 5 inches, andblade will not turn
Sounds like the motor is frozen - maybe oil level was too low - happened to me when it went up in a puff of smoke as it chugged to an inglorious *****!
Aug 26, 2017 | John Deere Garden
Why does my john deere 997z diesel cut off after only mowing 30 to 45 min ? It will crank back but cut right back off it has to sit a couple of days to run again
check for water in diesil change fuel filter see if that take care of it the next thing put a ignition coil on it, or then do valve job for damaged valves
Sep 03, 2014 | John Deere Garden
My john deere push mower starts fine mows for 10 min quits wont start so I took the the gas cap off looked at it put it back on push the prime bulb 1 time it started ran for 10 min quit did the gas cap...
I'm not sure of the model number of your mower or engine to know the fuel and carburetor set up. I do have one easy thing to try though as it sounds as if a vacume is building up in the tank. Try putting a half of tank of gas in it, leave the gas cap off, and see if it continues as it was or if it runs ok. If this stops the issue your cap vent is pluged up. I hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 03, 2013 | John Deere Garden
Mower blades stops running
check bearings in the spindles and check belt tensions.
Jun 15, 2013 | John Deere Garden
14.5 horse I/C ohv with oil
sounds like the needle valve and seat in the carb is bad
Jun 02, 2012 | John Deere Garden
Have an old model riding lawn mower, the mower stated to smoke under the engine. Stop for a while to cool off and started mowing again and cutting belt broke, replaced it. Now the blades want cut, but when...
try removing the belt and try to spin the blades by hand. are they stiff to turn? if yes try to oil the bearing assys up under there and spin em again. if that seems to work out put the belt back on and mow away again! seen this on a neighbors rider a few times
Nov 06, 2017 | John Deere Garden
Garden Logo
858 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
