Question about Sony DSC-T7 Digital Camera
How to Remove the Lens Cover on a Sony DSC-T7
The front cover on my T7 no longer turns the camers off and on. I know the switch went wonky, but I cant figure out how to remove the cover so I can look at the switch. I removed the 6 screws holding the case together but it binds at the top on the battery cover side. I guess I could use my Channel-Loks, but there must be a gentler solution.
  • Faleesh Apr 04, 2008
    Exact same problem here with the lens cover. It says it's closed when it is NOT. I'm completely attached to my camera but I have had it since December 2005 :( Repair costs are UP there.
  • 3 Answers
I was pretty rough with opening the case, but i got it off. just wiggle a lot and i found the back came off easier than the front.
Posted on Aug 08, 2008
It is only six screws, and you have to GENTLY wiggly the front cover off....Start at the bottom, and wiggle side to side to get it unattached at the top of the panel. I just got mine off. I'm having black screen problems....
Posted on Sep 25, 2007
SOURCE:
My Sony DSC T7 camera lens problem, When I slide the cover of lens, its says that "Lens cover Closed". so I am unable to take picture. Please help me. Thanks Anil
Mr anil there seems to be a problem with the sensor linked to the lens guard. Try to move the lens cover a few times and try to open the cover as much as possible just to initiate the sensor. If this does not solve the problem then you have to show it to a mechanic.
Regards.
Jul 14, 2011 | Sony Cameras
Sony cybershot dsc - t7. the display says ''lens cover closed''
It appears that you have already tried what I'd have suggested as a last resort. Apart from cleaning the contacts and removing the battery for 15 minutes there is not much that can be done.
In my opinion it is better to purchase new camera than to spend so much on this one. Note that sony may also charge you a checking fee if you decide to send the camera in hope for less costly repair than they estimated.
And yes, it would be fruitless to dismantle the camera if you are not qualified for this stuff. There are no user serviceable parts inside and also there are timed mechanical switches which can be difficult to reassemble without a proper schematic.
PS. Please do not use Vodka for cleaning electronic components as it contains small amount of moisture. Use Isopropyl alcohol.
Nov 28, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lens cover opens only a **** on Sony DSC-W80
Please read carefully below procedure how to remove "Barrier Block" (what you call Lens Cover)..
Turn camera power ON so Lens will extend.
Take out battery so lens will remain extended.
First silver ring needs to be removed with help of tweezers as shown in below image..
Now you will see 2 screws at front of lens, unscrew to remove barrier block (lens cover) as shown in below image..
You need to have new barrier block with following part number..
A-1205-001-A BARRIER BLOCK ASSY
Subject part is available in Part Store
Install new barrier block as shown following image..
Insert battery and power up camera to check does barrier block works fine.
Need further info, let me know.
Good luck.
Feb 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cybershot DSC-T7
Hey lmcconnell,
Error code E:61:00 means the camera has encountered a malfunction, and you should try initializing the camera back to the factory settings. Instructions on how to do this are on page 51 of your user manual, and I have included a link to a PDF download of your manual if you no longer have it. If this doesn't work I would have the camera looked at by an authorized service technician. I hope this helps!
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT7
Sincerely,
Allan
Go Ahead. Use Us.
Jun 22, 2008 | Cameras
Will not charge battery
Please contact the nearest Authorized Sony Service. If you need more info please advice. Arpi
Feb 16, 2007 | Sony DSC-T7 Digital Camera
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
Turn on the camera, cover lens is closed even though i already pull it down
if you open up your casing you will find that almost dead center on the front PCB, just to the right of the battery at the top of the empty battery area there is a box. possibly with some plastic fragment that is broken off. if you touch inside this box w/ something conductive it will think the lens is open. You can either fix this area or permanently solder it so it thinks it is always open. You can still turn it off using the button on the side of the camera
Sep 07, 2006 | Sony DSC-T7 Digital Camera
Small dent on lens cover
Put a sticker over it or a little stripe or somthing. The cover looks like its connected on the inside of the front case. Contact sony maybe they will send you a little slony logo sticker? you know how their logo is little dots? maybe you can find one on e-bay or somthing. Stickers cover everything :P
Dec 11, 2005 | Sony DSC-T7 Digital Camera
Sony DSC-T7 Digital Camera Logo
126 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
