Question about HP PSC 2355 All-In-One InkJet Printer
Carrige Jam When I send a print job to my printer, I get the message that I have a carrige jam....I have cleared everything....and it keeps doing it?
    Genius:
  • 2,120 Answers
Carriage assembly defective..uneconomical to have repaired. Sorry
Posted on Jan 27, 2009
Carriage jam hp c5550
I have a hp photosmart c5550 and it won't get the error message that sais carrige jam away help
Jan 24, 2012 | HP Photosmart C5580 All-In-One InkJet...
It keeps reading 'carriage jam, close door then press ok ... ' it will not stop.
If you open the printer cover you should be able to see a guide bar where the print carrige runs, if you can touch it feel if it is dry, if it is very dry (it may have black residue) then you will need to wipe the bar with a tissue or rag to clean it and then with a toothpick carefully add some singer oil (Machine Oil) maby 4 -5 drops along the bar, and slowly move the print carrige over the newly oiled section this should lubricate the bar again and stop your carrige jam issues
Feb 09, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Hp photosmart a520 series carrige jam nothing
Hello there You can still try this Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 12, 2010 | Office Equipment & Supplies
My hp photosmart printer is saying Error carriage jam, open dorr clear carriage jam and then press Ok to continue. Which door should I open and how do I clear the carriage jam? Linda
Without any paper in the machine I would try powering off and powering on. Lifting the scanner lid will clear so the carrige goes back to the correct side of the printer. Even rebooting the printer and loading the software will sometimes cause the carriage to go back to where it was supposed to be.
Jan 16, 2010 | HP PhotoSmart C4180 All-in-One Color...
Carriage jam
You could try clearing the jam and then removing power from the printer altogether to re-initialize the printer. However, if that fails either the printer diagnostics chip has gone awry or you have a virus.
Oct 28, 2009 | HP Photosmart 4180 All-in-One Printer
My ink jet cannon printer MP600 is saying i have a paper jam there is no paper in it and it is still saying this and wont let me access any other functions or print
Recheck all jam clearing areas on the machine. Open doors, reseat the doors. Check for safety interlock switches, they are small and hard to find.
make sure the acuators are still in place, on the switches.
With the power off, move the ink carrige over left and right make sure there is no paper back there.
Make sure the carrige comes to its home position.
Other than this, possibly malfunction sensor or main board problem.
Oct 15, 2009 | Canon Office Equipment & Supplies
Carriage Jam - HP Officejet J3680 All-in-One
the silver bar the carrige slides on has lost all its lubrication. Try putting some chapstick on the silver bar
Sep 30, 2009 | HP Officejet J3680 Multifunction Printer...
I get an error messege (carrige jam)
I have found that when I slide back the carriage to the left by hand and expose the bottom right hand side, there has been an accumulation of ink that is preventing a part from sliding from front to back. Inspect the bottom right hand side where the black and color cartridges normally sit. You will find a flat sliding piece directly beneath the position where the cartridges normally sit, that will not slide forward to the front of the printer and back towards the back of the printer easily because of the ink that has accumulated and is causing a drag. I used q-tip swabs and some alcohol and cleaned out the rails that the piece slides in. Use a flashlight to inspect. After cleaning it appears that it is printing normally again. Repeat the process as needed. Bob in NC
Jan 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP6200 all in one printer "carrige jam clear carrige jam then press ok" There is no carrage jam or any other jam that I can determine. When turned off for an extended time then turned on it...
In order to help you better let me provide you a web-link to a web document which has clear graphical representation of the solution.
Click on the link below to open webpage and follow all the steps given in web document:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00304007&dlc=en&lc=en&jumpid=reg_R1002_USEN
Thank you.
Nov 28, 2008 | HP Office Equipment & Supplies
Carriage jam
This can be many things, but inspect the paper path for anything stuck. remove the cartridges with printer off and see if you can manually move the carriage you may need to force it a little but not allot, sometimes it may jump a gear causing this error.
move the carriage away from home position and turn on, the printer should reset the carriage position.
hope this helps
Jan 07, 2008 | Office Equipment & Supplies
HP PSC 2355 All-In-One InkJet Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
