Need codes as well as instructions to program Sanyo tv and direct tv reciever
    Genius:
  • 1,669 Answers
It might be easier to just go out and purchase a Universal remote control at your large drug store or electronics store. They include instructions for getting the codes from each device you need controlled and storing those codes.
Posted on Jan 20, 2013
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
  • 7 Answers
SOURCE: need codes for a Sanyo TV
0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
Posted on Jul 30, 2008
hemla
SOURCE: direct tv codes
THE CODE IS 11610 AND IT WORKS!!!! :)
Posted on Apr 25, 2009
whytfang
  • 170 Answers
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's right say it with me....He...Rocks...hehe...but anyway here is the link address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
Posted on May 20, 2009
  • 374 Answers
SOURCE: need Sanyo TV code numbers
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
Posted on May 25, 2009
Do not have code for a SANYO tv or instructions how to program remote
Setup codes are: 0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 14, 2012 | Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Oct 24, 2009 | Philips Televison & Video
I need the codes for a sanyo tv to program my philips universal
please find the similiar type of the tv (must good tv) remove both tv memory ic and copy from the good tv.use memory ic copier all settle ok
Jun 06, 2009 | Sanyo DS27800 27" TV
Programming my directv remote to operate this tv, codes dont work
I just programmed mine by using my direct tv remote...
Go to MENU on the direct tv remote
Then highlight HELP & SETTING and press SELECT.
Press SELECT on Remote in the left menu.
Simply follow the onscreen instructions to program your remote. IT IS IMPORTANT TO MAKE SURE YOU HOLD ON AND SEE THE GREEN LIGHT ON THE DIRECT TV REMOTE FLASH TWICE, otherwise it won't work....which is what I think is happening in your case. Good luck.
Apr 22, 2009 | Sanyo DP42848 LCD TV
My Direct TV RC64R remote won't work
Yes 10030 is the code. Many Thanks to the Guest.
Sep 29, 2008 | Televison & Video
Finding codes
how program my control sanyo for tv curtis mathes
Sep 12, 2008 | RCA DIRECTV Satellite Remote Control
Need help programming
use your users manual to get the program of your apliances. and follow the instructions. I got a universal/ all-in-one remote control for apliances and its working for my dvd tv and my digital reciever. hope that would help.
ps.
instructions can be seen at the back tof the remote or at the users manual.
Jan 21, 2008 | One For All URC-3021 Remote Control
Remote Control Programming
sanyo uses code 10154 ,hold mute and select at the same time until the greenlight flashes twice then enter code and press power
Dec 06, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
