Question about Dryers
My ge front loading gas dryer turns off when there is still time left, to start it again i slam door, whats wrong?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
You may need a new door switch. Check the wire connections and be sure the switch is secured.
Posted on Jan 20, 2013
  • 1462 Answers
SOURCE: GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Posted on Mar 28, 2007
Jimster
  • 240 Answers
SOURCE: Frigidaire Front Load Dryer
Reach inside the drum and feel the drum inserts to see if one of those has come loose. Sometimes you can have one of those screws back out and hit something on the inside. Could also be a bent drum (doubtful unless its been overloaded or abused real bad) a front slide is bad (would probably cause squeeking or grinding noise) or rear bering (also should squeek or grind). Good Luck!!! Jim
Posted on Sep 09, 2007
  • 1314 Answers
might have a dead spot on the armuture or lint in the motor and or the centrifcal switch try taking it apart and cleaning the motor if that doesnt work replace the motor
Posted on Feb 15, 2008
docjohn174
  • 943 Answers
SOURCE: my ge dryer wont start
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Posted on Dec 16, 2008
  • 4 Answers
SOURCE: high efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Posted on May 30, 2009
Have a GE electric dryer model DJXR433EC2WW. Whenever I select the dryer mode/time option, the dryer turns on by itself without turning the start switch (door closed). The dryer only stops when it...
I have seen that in those dryers before and it has always been the motor that is causing it to start without engaging the start switch.
GENE
Sep 16, 2011 | GE Dryers
MI have a maytag washer the works when I slam the door repeatedly. Whats wrong ?
I would suggest the interlock or door sensor is malfunctioning which will only become worse each time you have to slam the door.
Sorry but service engineer call ;-0)
John C
Feb 28, 2011 | Maytag MAH2400A Front Load Washer
Gas dryer runs but no heat
Those coils are probably getting hot and quitting then after a long time they cool off and work some more then quit again.62a13a2.jpg2720ab1.jpg
Apr 11, 2010 | GE DVLR223 Dryers
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Dryer won't start after I slammed the door
The door switch is probably in the next room somewhere.
Look in the hole around the edge of the dryer opening. There should be a switch in there. It's most likely been pushed back so the door post/actuator does not engage it.
Switch need to be put back in place.
May 29, 2009 | GE Dryers
How to get the front panel off GE Profile Harmony
Here's a simple overview of what you have to do:
You actually don't remove the back sir, but that's okay, that's a common misconception for this model dryer. The proper way to disassemble this particular dryer is you start with the top. You have to start with the removal of the control panel, then the top of the dryer. What I would consider the top cover. Then you'll have to remove two plastic brackets. Then you have to remove the front. There's two aluminum brackets in each corner, remove those. Open the door and there'll be two more screws to remove on each side. You have to lift the front just a little and then pull towards you. I forgot to mention, before that part, you'll need to ensure you are disconnecting the electrical wiring. There's almost no chance of connecting the wrong ones even if you forget. GE made this part novice proof. Once you get the front removed, you'll see the lint/trap. There's a couple of screws on either side of the aluminum housing. Not much to it. Let me know if there's anything I can clarify further. Have fun!
Mar 31, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Two year old ge gas dryer won't get hot
Start by replacing the damaged timer and conducting a tutorial on CW vs. CCW.
Mar 30, 2017 | GE DBXR463GB Gas Dryer
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
