Question about Hitachi 32LD8700 32 in. LCD Television
Hitachi Invalid Scan Freq
When connecting a computer, the screen shows the message "Invalid Scan Freq"
Scanning function is not working. Computer is connected - it prints to printer but when attempting to scan documents, message says operation is invalid - check computer connection.
It would be useful to know the device you are using. I will assume it is a common multifunction device.
Defragment your hard drive
uninstall your driver
reinstall your device driver from the supplier's web page
Oct 22, 2017 | PRINTER Office Equipment & Supplies
Screen flickers and color wont show
What kind of cable are you using, and how long is it? Does it work for connecting the PC to a monitor? And are there any splitters on the line?
Jan 30, 2014 | Hitachi CP-X253 Projector
Hitachi rear projection hd tv. message on screen says invalid cable card installed. remove to restore video access. there is no cable card installed as we have cable service through a cable company. j
Two things to try here---first is unplug the set for a while and plug back to see if the microprocessor in the set will reboot.
Second look to see if slot for the card has anything at all in it or is dirty.
if dirty blow it clean and repeat unplug procedure Note: very few of these sets have a hard reset feature but if all else fails call Hitachi customer service with the model number---they have some very good people answering the phones and an extensive data base on sets/problems.
Apr 11, 2012 | Hitachi 57F500 57" Rear Projection...
Invalid sim on screen
If your phone show Invalid SIM it means the SIM card is corrupted you will have to change the SIM card.There is no other option.
May 19, 2010 | Motorola Mobility TracFone C139-4 Cellular...
Invalid scan freq.????
Windows 95??
If it was me, I'd install a new Linux distro, then run Wolfenstein on Wine (or PlayOnLinux).
Wolfenstein Supported software PlayOnLinux Run your Windows applications...
Apr 08, 2017 | Cornerstone Professional P1500 Monitor
"Invalid Format" message
This should help you. I think Chris Duckworth said it best. "sounds to me like your refresh rates or resolution may be set too high on the XP machine."
Go to this website to get the rest about setting up your tv as a monitor. Type invalid in the word search to get to the relevant section.
http://www.inspectmygadget.com/2007/06/11/how-to-connect-your-pc-to-your-television-and-stereo/
Mar 26, 2009 | LG L1915S 19" LCD Monitor
Invalid dim
turn off the stat plot by pressing 2nd button and then the STAT PLOT button.
Mar 12, 2009 | Texas Instruments TI-84 Plus Silver...
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
Invalid format
the comp is set to an unsupported screen res. set it to 640x480 and try again.
Dec 04, 2008 | Televison & Video
Invalid media
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 22, 2007 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Hitachi 32LD8700 32 in. LCD Television Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
