Question about Cadex CPB2350 2" 23 GAUGE PINNER PIN NAILER KIT
Hamer won't return on the cadex pin gun - Cadex CPB2350 2" 23 GAUGE PINNER PIN NAILER KIT
2 Suggested Answers
  • 1082 Answers
SOURCE: I didn't get an instruction
Check out this forum. Talking about your nailer.
You could ask them for advice and help, perhaps someone has what you need.
http://forums.jlconline.com/forums/showthread.php?t=48870
Posted on Nov 12, 2010
My gun won't **** into shooting position and I have pin of some sort that fell out how do I repair it
Anon, take into a gunsmith/gun shop and they will repair firearm and make sure it is safe for use.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 25, 2016 | Miscellaneous
My hitachi nail gun NV 50AA will fire, but won't advance the nails on a regular basis
NV50 nailer is very difficult to repair due to complicated feeder /feeder spring / feeder retainer pin design. You most likely need to replace the orings on the feeder piston. Problem is that you must remove the feed pin/ spring to get the piston out. If you are going to attempt to replace the orings, study how the pin is installed otherwise you will make it worse. Order new springs (2 different springs ) and install them when you are going back together. Good luck
Mar 03, 2013 | Tools & Hardware - Others
Gun is full of nails, but acts like it is empty (the plunger won't advance). You go to tap it with the trigger pulled, and it just does nothing. Seems like firing pin is not getting air or somet
If no air is leaking from the gun, take out the nails, remove trigger by removing 3mm hex head bolt to expose the trigger pin. With air connected and side door open so that you can see the feeder, quickly depress the trigger pin with finger. Gun should fire. If gun does not fire (only makes air sound at trigger) dissconnect airline, remove head and lube headvalve with white grease and reinstall. Test again. If ok replace trigger. If still no joy, replace trigger valve with new factory or generic (part # TVA6). If gun fires but does not activate the feeder claw, remove two 6mm hex bolts from front of gun and split apart upper and lower body and check white oring (part # 149885) Good luck
Oct 16, 2012 | Stanley Bostitch Rn461 Gun Coil Roofing...
SB 1842bn
When a firing pin won't return it's usually caused by damaged o-rings inside the gun. The most likely culprits are the o-rings around the outside of the cylinder or the rings on the drive piston. Another cause could be a cracked cylinder or bent driver. Remove the cap on top of the gun and check the condition of the o-rings, cylinder and driver. You'll have to order any parts that need to be replaced as Bostitch doesn't make a rebuild kit for this gun. Don't forget to lightly oil the o-rings with pnumatic gun oil when reassembling the gun. Most pin and finish nailers say they are oil-less but they still need a drop once in a while to keep the o-rings from being damaged.
Feb 14, 2012 | Stanley Bostitch HP118K 23 Gauge Headless...
Firing pin won't return SB 1842bn
Lubricate it and crank up air pressure and return spring.
Feb 14, 2012 | Stanley Bostitch Sb1842bn 18 Gauge Brad...
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
Framers 702xp won't drive a nail more than an inch into wood and sometimes won't retract the pin all the way.
Before you use the tool put a few drops of oil into the air line input. The pin may be sticking. You could try spraying WD40 into the area where the nail comes out also.
Sometimes dirt can build up in the region that the pin slides in and other moving parts and cause them to stick so you may have to dismantle the gun to clean it. Spray WD40 on all moving parts before re-assembly.
Jul 14, 2011 | Senco 2K0013N FramePro 702XP 2Inch ...
I didn't get an instruction manual with my 23 gauge Cadex Pin Nailer. I've only used it for about five minutes and now it won't fire pins any more. Possibly there is a pin jammed but without a Manual I...
Nov 12, 2010 | Cadex CPB2335 138" 23 GAUGE PINNER PIN...
Cadex CPB2350 2" 23 GAUGE PINNER PIN NAILER KIT Logo
Top Cadex Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Cadex Air Tool and Compressor Expert? Answer questions, earn points and help others
