Question about Samsung SyncMaster Computers & Internet
Samsung syncmaster 740nw lcd monitor shows negative image
Hello I have an 17"samsung syncmaster740nw lcd monitor. i have problem in color missing . pls hlp
skotkolr
  • 558 Answers
SOURCE: driver of samsung monitor
I will go with Cropp on this one however if you cant find it at that site you may also try driver guide.com
Posted on Jun 19, 2008
SOURCE: No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
Posted on Oct 22, 2008
SOURCE: i have samsung syncmaster 740nw how can i increase
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Posted on Jan 13, 2010
budmrtn
  • 11361 Answers
SOURCE: Samsung SyncMaster 730B LCD monitor isn't backlit at all
Most failure in LCD monitors are due to cheaply made caps being use. If you are going to DIY repair, please read below, or if you are going to have it fixed then at least you will know if you are being ripoff or not.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 22, 2010
SOURCE: Vga cable color code of
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the 5 - DDC Return 10 - GND-Sync/Self raster 12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
Posted on Aug 03, 2010
Why my display show plug and play monitor instead SyncMaster 732nw?
U NEEDS TO INSTALL MONITOR CD COMES ALONG WITH MONITOR. THEN IT SHOWS SYNC MASTER. AND THE COLOR SETTINGS WILL BE ALIGNED AUTOMATICALLY.
Apr 17, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Hello My PC monitor/CRT 17 inch. not getting
check the signal cable bend it in on condition and look what difference in color occurs if so then replace the cable if not that fault then ther is a dry solder on the base of monitor find out and clear it
Apr 05, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung Syncmaster 740NW vertical blue stripe
I've never opened one of these units, but I think you're right...a broken, cracked, or "cold solder joint"...had that problem on boards a lot of times. What has been assembled, should have a way of disassembling, unless the plastic was molded or glued after assembly, which is almost never the case, to my knowledge. Sometimes screws are hidden under labels, paper or metal plates, anywhere, really. If you can drop by a computer repair shop, you might be able to pick their brains about where the screws are, just depends on the person working there. Only other choice is to get the repair manual, but they're expensive and hard to locate, sometimes. Anyway, keep working on it, I think you'll figure it out!
Mar 14, 2010 | Samsung 931BF 17" LCD Monitor
I have syncmaster 740NW samsung lcd monitor i am using it for 2 years but today automatically its screen has been blurred even it is working slowly not clearly visible
If you are DIY'er go to Display in Control Panel and reset to default, this might work. If not, try a RESTORE POINT roughly before condition started.
Have you kept up with your computer MOT's
ie Defragging?
Nov 14, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Applications are cant display on full screen
you can serach it in this site(google.com)
i hope i can help you
Sep 03, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Blue vertical line appeared on samsung 740nw monitor
Make sure the monitor cable is secure on the computer and on the back of the monitor.
Try the monitor on a different computer.
If the lines are still there then contact Samsung for help.
If you are lucky your warranty is still active.
If this helps please vote for my solution.
Aug 27, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Computers & Internet Logo
26 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
