Casio HR-150TER Calculator
Problem for Casio HR-150TER Calculator
Trying to change the tax buttons on my CASIO HR-150TER
By jbrookes on Jan 26, 2009
I have held the CA button, then the % button, input 15, pressed tax + then % button but it comes 16, and the tax - button is 14 can you please help.
Same Problem
Jan 29, 2009
-   1: unable to get the calculator HR150TER to change any of the tax rates beyond that session.
2: I was given the machine but no manual
3: When I change to print or memory mode the screen swows an E in left hand corner (presume error) I can not remove this and the machine locks up
Help please-   pipeman64
Best Solution
posted on Sep 11, 2009
Very Helpful)
Netizen1993
Rank: Apprentice
Rating: 100%, 2 votes
I solved this problem..
1. press and hold your % Key the zero on your display will disappear While the % is pressed, press and hold your CA key. After a short delay the calculator will print a line #--------------- when this happens release the keys.
2. Enter your tax rate for me this was 7.75 then press your Tax+ key.
now your rate is set.
You can then use this key as normal. :)
Hope this helps.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Casio HR-150TER Calculator
Questions and Unsolved Problems for Casio HR-150TER Calculator
Do you recommend Casio HR-150TER Calculator?
Answer
Answer
How do you replace the color ink?
Answer
How do I re-program This machine? The machine was used for a retail clothing store.  Now... (More)
Answer
how do you programme a change of vat rate on the casio hr-200ter
Answer
Manual for Casio HR-150TER calculator
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Casio HR-150TER Calculator:
Top Calculator Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Calculator Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
