Fisher & Paykel, Disheasher, model: DW60CCX1 has fault E9, water valve fault. How do I fix it?
2 Suggested Answers
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Not getting hot water
Hot water valave faulty if your hot water tap is open and can pass water. Otherwise fault inside the control board. It also can be fixed but first look at the hot water valve and the btap.
Apr 01, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel DishwasherDW60CCX1 - bought new 22.5.12. Error code E9. How to fix this please, as not in the instructions book!!
The code like E9 or F9 in F&P dishwasher usually implies controller fault. No solution but to call authorised technician unless you know how to replace the controller. Need to have a diagnostic tool to check what is happening. You should still be under factory warranty.
Dec 22, 2012 | Fisher and Paykel Dishwashers
Error code e9
I think I already responded to this. Your dishwasher should be under factory warranty.
What does the fault E9 mean on our Fisher & Paykel DW60CC dishwasher mean and how do we fix it?
The fault E9 means the controller has a problem. Obviously it is not a complete fault as you are still getting the fault codes. Some key circuit in the controller has become faulty and this prevents dishwasher from working. Usually the controller needs to be replaced. But first try to turn the mains power off and back on after a short delay. This might reset the controller (boot up).
Dec 09, 2012 | Fisher and Paykel Dishwashers
Fisher@paykel aqua smart washer shows fault code49.
Fault 49 on F&P agitator models is bad cold water valve or wires on it disconnected.
Apr 25, 2012 | Fisher and Paykel Washing Machines
Cold&hot water valve dont seem to unscrew or do you have to buy the whole part
Fault 49 would most possibly be faulty motor controller board.
Not the water valves at all.
Mar 22, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
Jun 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fault 52
Code 52 is a loss of water during recirculation cycle. Possibly due to a faulty divertor valve. Check to see if water is circulating back into bowl & no water escaping out of the drain hose. May also be caused by a faulty motor controller.
Jan 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Washing Machines Experts
