Question about Intel Desktop Board SE440BX-2 Motherboard
SE440BX-2 BASEBOARD-WANT TO INCREASE HARD DRIVE SIZE.
MY SYSTEM CAME WITH A 8GB DISK WHAT IS THE MAX DISK SIZE I CAN USE. i TRIED A 160 GB ATA WESTERN DIGITAL BUT IT FAIL TO FORMAT. PARTATION THIS DRIVE FOR 20,40,60,AND 80 PARTATION AND IT STILL FAILED THE FORMAT.. WHAT DO I NEED TO DO
  • 565 Answers
You may need to update the BIOS. When first booting press F2 to enter your current bios. The latest bios for your motherboard is version P17. Also if you see a number with an "86A" in it, the number after that number should be "0024". The bios dated 9/1/2000 is the latest version.
If you decide to update the bios, be _very careful_ to follow all instructions exactly, otherwise you can render your computer useless.
While you are in the bios, and before you try updating the BIOS, check your IDE configuration to make sure that the IDE controller is set to "both." Also in the primary IDE master submenu, be sure that "LBA Mode Control" is set to "enabled." When exiting the bios, if you made any changes described above, be sure to select "save on exit" or similar. Re-boot and try the new drive.
Here's the update website from *********** board.
http://www.intel.com/support/motherboards/desktop/se440bx2/
Posted on Jan 26, 2009
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Need specs
Systemax Ascent KMA3500 Desktop
Processor :AMD Athlon 64 X2 2.3 GHz
Installed Memory :2 GB (DDR2 SDRAM)
Operating System :Microsoft Windows Vista Business
Video Output Interface :PCI Express
RAM :2 GB
Max Supported RAM :4 GB
Installed Video Memory :128 MB
Supported RAM Speeds :800 Mhz
Hard Drive :160 GB
Hard Drive Interface Serial ATA II
CD / DVD :CD-RW/DVD-ROM (Combo)
Graphic Processor NVIDIA GeForce 6100
Integrated Audio Realtek ALC833
Networking
Networking Type Integrated 10/100 Network Card
Dec 18, 2009 | Systemax Ascent PC Desktop
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Which HDD Supported To Acer4710z Laptop
Acer Aspire 4710 General
  • Built-in Devices Stereo speakers , Wireless LAN antenna
  • Width 13.5 in
  • Depth 9.7 in
  • Height 1.7 in
  • Weight 5.7 lbs
  • Color Black/light gray
  • Localization United States
  • Notebook type Thin-and-light (4-6 lbs.) , Budget
  • Screen type Widescreen
  • Wireless capabilities IEEE 802.11b , IEEE 802.11g
Processor
  • Processor Intel Pentium Dual Core T2080 / 1.73 GHz
  • Multi-Core processor technology Dual-Core
Cache Memory
  • Type L2 cache
  • Cache size 1.0 MB
RAM
  • Installed Size 1.0 GB / 4.0 GB (max)
  • Technology DDR2 SDRAM - 667.0 MHz
  • RAM configuration features 2 x 512 MB
Storage Controller
  • Storage controller type Serial ATA
  • Storage Controller / Serial ATA Interface Serial ATA-150
Storage
  • Floppy Drive None
  • Hard Drive 120.0 GB - Serial ATA-150
  • Storage Removable None
  • Hard drive type Portable
May 30, 2009 | Computers & Internet
Seagate ST3160215A Hard Disk PCB Card Short-160 GB ATA
Hi sunny_2003,
There are many hard drive pcb supplier such as http://www.hddzone.com/seagate-pcb-c-1.html
Be sure to backup your data.
Mar 11, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
How to upgrde sony pcv-rx470ds desk top hard drive; what is the max gb?
Looks like this unit is a couple of years old by the specs.
160 to 200 GB would ba a good size to install in the unit.
It is easy to replace the hard drive. Just remove the old one and install the new by reversing the procedure. Just make sure that the jumper is set to master( which is how the new ones come jumpered)
  • Intel® Pentium® 4 processor 1.50 GHz (2)
  • 128 MB PC-800 RDRAM (expandable to 512 MB)
  • 400 MHz Front Side Bus
  • 60 GB (3) Ultra ATA/100 hard drive
  • 16X max. DVD-ROM/40X max. CD-ROM
  • 12X8X32X max. CD-RW Drive
  • High-speed Internet ready with 10 Base-T/100Base-TX Fast Ethernet
  • 4X AGP 3D Graphics Hardware Acceleration (NVIDIA® GeForce2 MXTM )
  • 32 MB Video Memory (SDRAM)
  • i.LINK® (IEEE 1394) chipset on motherboard (1)
  • Front accessible i.LINK (IEEE 1394) interface and USB connections (1)
  • Programmable VAIO SmartTM Keyboard
  • V.90 compatible data/fax modem
  • Wheel mouse
  • External stereo speakers
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Feb 20, 2009 | Sony VAIO PCV-RX470DS PC Desktop
    POWER FAILURE AFTER HD CONNECT
    Ok ATA is the standard for data transfer, in this case it is IDE. 133 is the max transfer rate. I have removed the hard drive from ours (bought from dell directly and has not been changed) and the hard drive is set as Master (no jumper). Try this if it does not work i would test the hard drive in another system or in an inclosure.
    Nov 19, 2008 | Dell Inspiron 2200 Notebook
    Seagate 160 gb capacity problem
    the harddrive size is in another measurement system and the actual size of the drive is exactly what you are seeing 152.
    here you can see how my disks show
    894a905.jpg 160GB disk - 152,66GB
    1000GB disk - 931.51GB
    that is correct.
    Jun 15, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
    New hard drive 160 GB ATA can't be partitioned
    why dont you try 40000 in the first partitioned..if doesn't work.. try fix your hard drive using a seatools, a bootable disk, that can detect and repair a bad sector for a hard drive..
    Feb 26, 2008 | Computers & Internet
    Intel Desktop Board SE440BX-2 Motherboard Logo
    154 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
