Question about Kenmore 24942 Top Load Washer
The washing machine is setting off the breaker at the electrical
The machine runs for a few minutes then sets off the breaker
  • 15,935 Answers
It appears your timer or motor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
When you said turn off circuit breaker did you mean from electrical panel or is there something on dishwasher
The breaker this should be referring to is inside your home's panel box. Sometimes electronic devices will have an inline fuse to stop power surges from damaging expensive delicate boards with hard to find ICs, but this is a fuse that burns an electrical element and has to be replaced after it's been used, or in other words it's a one shot thing, versus a breaker which is a mechanical device that moves a set of contactors when it senses an over current situation and can be used repeatedly. Unfortunately you didn't ask this question with the string that your first question was linked with so I don't know the original problem, but I have never known of a washing machine that had an on board circuit breaker, and know that many do not include inline fuses either.
If you have additional questions please post (to this string so the can be easily found) and if you found my answer helpful please up vote it, and let us know your results.
Feb 28, 2015 | Washing Machines
Washer started and then stops mid cycle
Try unplugging it for a minute and plug back in, that should reset it.
Jan 09, 2018 | Maytag Neptune Washer
Washing machine was operating machine stoped 10 minutes after operating and will not start water is in the machine it did not drain
Hello, first check if the breaker triped in the electrical panel box (fuse box--old name). If it has not triped a breaker. Unplug your washing machine and wait about 10 or 15 second and replug the washing machine into the electrical socket. Don't turn it on. There should be a reset button. Push the button first, then turn on your washing machine. I hope this works for you. GB...stewbison.
Aug 25, 2011 | LG WM-2277HW Front Load Washer
BREAKER TRIP AFTER 8 MINS .WORKED ONLY ON PERMANENT PRESS FOR A YR NORMAL ..WOULD TRIP BREAKER ON LOW AND HEAVY SETTING AFTER 5 MINS CYCLE.
This problem might be in your house electrical system rather than the dryer but it will take some troubleshooting to figure it out.
1. First make sure that you are connected to a 30 amp circuit breaker. If not then that is the problem!
2. Use a clamp on amp meter to see what the dryer is drawing from your electrical panel before it trips. If it is below the rating of the 30 amp circuit breaker when it trips, then your circuit breaker is defective.
3. If the dryer is drawing more than 30 amps it is in your machine and you will need to troubshoot that. Since you stated the times - is it always the same and does not vary? Then you have to figure out what you dryer is doing at the 8 minute mark and each machine is a little different. Soem machines go into a tumble air only mode for the first few minutes before kicking on the heating elecment. If yours is that was then it is the heating element, thermostat or something to do with the heating circuit.
Jun 20, 2011 | Dryers
Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
May 02, 2010 | Electric Mobility Mobility Electric Power...
General Electric WBVH5200J Front Load Washer Washing While using speed wash setting, it... Answer Setting the washer on speed wash for 38minute cycle, the machine is working for 50+ minutes. At... (More)...
Your washer may be doing this because you use far too much detergent or non HE detergent. To solve, use 1 eyedropperfull of liquid HE detergent, or one half teaspoon of powdered HE detergent dissolved in extremely hot water. Try running a Basketclean cycle with vinegar to remove the extra suds which can STILL be lurking in your drums and lengthening your rinsing time.
Feb 05, 2010 | General Electric WBVH5200J Front Load...
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
RE: Roper Electric Dryer, front load
You have a ground fault or short . Disconnect dryer and remove small panel that holds the cord. Check if any wires are frayed, loose or touching any other metal objects.
Jun 29, 2009 | Dryers
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Washing Machine GE Profile/prodigy
you have a dry on your programmer you should not do this your self i would go down and see your local second hand shop who can help you with is they normally do jobs like that appliance shop is the best place to go it will be cheap
Dec 03, 2007 | GE Profile Prodigy WPSE4200A
Kenmore 24942 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
