Question about RCA D52W19 52" Rear Projection Television
D52W19 ITC222 Chassis 52" RCA PROBLEM SOLVED
Bought the RCA 52" did not buy extended warranty.Was very happy with pic quality etc..However right out of the box it had this high pitched ear piercing squeal for about 2 minutes when first turned on but then would stop.I feel I should have returned it then but this noise stopped and you know how it goes.The problem later was it did not want to come on for several tries but then would.This seemed to get worst and finaly would try three times and nothing before 1 minute wait to re-try again.I called RCA which was a waste of time and even visited the local RCA listed repair man in my town.You only get one chance to make a first impression and he came off to me as one lame duck who must have took a trip on acid or something and never came home.But then again he could be an electronics genues for all I know but I decided to punt.After walking through his maze of tv's in this old house he called a repair shop I decided to fix it myself.I am not a tech but electronics is a hobby of mine.This is what I did and now it works great.Hope this helps someone. Hope the techs don't hate me for giving this up.Unplug the TV of course and remove the back lower panel.Blow the dust off so you can see the components clearly.Have a bright light and look at capacitor CP158 16V 2200uF Green in color with gold (NEG)stripe which is located on rear board to your left.This baby was hard to see because it sets/hides behind the metal heat sink fence.Mine was bulged at the top and had brown ozz coming out at top.None of the rest looked this way.You have to unplug several ribbon cables and power wires to remove board so you can flip it over and un-solder it to put in a new one.The board just slides out easyly.(Important)note which side gold negative band is on Capacitor new one has to go in same way or it will pop.When I removed the Cap. and put analog meter on it it swung ok but ESR was off the scale at 6.5 to 7.0 It should be .05 this was my fix and it is like new again.I already had this Cap. but this is 92 cent part you can get at Radio Shack Jameco etc...Make notes of where wires unhooked from but they are pretty self explan.Take your time and double check your work.Hope this helps.I really missed this TV but now back in action. Yoba439@windstream.net PS don't touch the big twin big fat brown caps on right board these will bite at 250 Volts.Good Luck
  • 2 more comments
  • Jeff Fowler Jul 17, 2007
    Correction on Cap.location # is CP150 not CP158 Made by LELAN. I decided not to use an RCA replacment cap. since their originals seem to be defected.Rubicons caps and many others are good quality.
  • Anonymous May 24, 2008
    Green lignt flashes 3 times. Trans. or cap now screams for 3 secs off 2 secs.
  • texasbigscre Jun 24, 2008
    my ty is not power
  • wpnsexpert Feb 17, 2009
    i took your advice mine was doing the very same thing i have had absolutely no electronics experience what-so-ever using your solution i was able to take a tv i was going to throw out and repair it for a cost of only $5 you saved me alot of money thank you so much!!!!
Buy other tv,
Posted on Jul 17, 2007
SOURCE:
Rca d52w17 convergence off on 1080i signal only tv works fine with 480p signal.
you will need to adjust the geometry and convergence defaults for both the 1080 and 480 seperately then save. You can get the CD called the ITC222 chassis convergence and alignment CD which shows how to do that from www.tvrepairworld.com
May 26, 2010 | RCA D52W19 52" Rear Projection Television
Keeps shuting off.
Hello bondaddy60, I believe this may be your problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 09, 2009 | RCA D52W19 52" Rear Projection Television
My rca d52w19 will blink, but not come on.
Hello ,
I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you,
I hope this helps,
Shuttle83
May 24, 2009 | RCA D52W19 52" Rear Projection Television
MY RCA MODEL NUMBER D52W19 WONT TURN ON!
Hello , I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 17, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w19 chassis itc222
The fuse rating should be on the metal side of the metal ends of the glass fuse. Very hard to read amps and rating, may need a jewelers lupe. Or take the remains to Radio Shack.
Feb 15, 2009 | RCA D52W19 52" Rear Projection Television
RCA HDTV chassis # ITC222 will not come on.
most likely the Flyback 259296 and CP150 you can get replacements at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Nov 25, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
You need to replace the flyback its flyback 259296 and you can get a new replacement for 47.99 at the following link.
Jun 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
1,053 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
