Question about Microsoft EXCEL 2004 for Mac
Excel file will not open
Hi. My team at work has been working on this Excel file, which is full of macro commands and links to other documents. It currently lives on our company 'intranet' or server, where most of company documents and files live for others to access.
This morning, it was discovered that the file will no longer open.
Typically, when opening, the macro-enabling window appears. Usually I choose Enable Macros. And then a window regarding the links to other workbooks appears, for which I usually choose Ignore Links... and then the file would open.
But now, regardless of whether I enable or disable macros, or if I ignore the links or try to update them, the excel file refuses to open. When disabling macros, a message window appears, stating that 'This workbook contains a type of macro (MS Excel 4.0 macro) that cannot be disabled. There may be viruses in these macros'. I'm not sure if this is the problem or not.
Anyway, what follows is a portion of the error report that is returned after the 'The application Excel quit unexpectedly' message window appears: ----- OS Version:     10.4.11 (Build 8S2167) Report Version: 4
Command: Microsoft Excel Path:    /Applications/Microsoft Office 2004/Microsoft Excel Parent:  WindowServer [59] Rosetta: Yes
Version: 11.5.0 (11.5.0 (080428), © 2004 Microsoft Corporation.  All rights reserved.)
PID:    380 Thread: Unknown
Exception:  EXC_BAD_ACCESS (0x0001) Codes:      KERN_PROTECTION_FAILURE (0x0002) at 0x00000018
Thread 0: 0   LaunchCFMApp 0xb80a564f 0xb8000000 + 677455 1   LaunchCFMApp 0xb809fb15 0xb8000000 + 654101 2   LaunchCFMApp 0xb80bd72e 0xb8000000 + 775982 3   LaunchCFMApp 0xb811e403 spin_lock_wrapper + 1985
Thread 1: 0   LaunchCFMApp 0xb822fa6b strchr + 72 1   LaunchCFMApp 0xb81cb487 pthread_cond_wait + 3114 2   LaunchCFMApp 0xb816765e catch_exception_raise_state_identity + 318 3   LaunchCFMApp 0xb8166b9a CallPPCFunctionAtAddressInt + 177124 4   LaunchCFMApp 0xb8166a91 CallPPCFunctionAtAddressInt + 176859 5   LaunchCFMApp 0xb816775c catch_exception_raise_state_identity + 572 6   LaunchCFMApp 0xb8200c00 pthread_create + 1124
Thread 2: 0   LaunchCFMApp 0xb813446b spin_lock_wrapper + 92201 1   LaunchCFMApp 0xb815fa34 CallPPCFunctionAtAddressInt + 148094 2   LaunchCFMApp 0xb8162601 CallPPCFunctionAtAddressInt + 159307 3   LaunchCFMApp 0xb80c805c 0xb8000000 + 819292
Thread 3: 0   LaunchCFMApp 0xb813431a spin_lock_wrapper + 91864 1   LaunchCFMApp 0xb814d4b8 CallPPCFunctionAtAddressInt + 72962 2   LaunchCFMApp 0xb80a626f 0xb8000000 + 680559 3   LaunchCFMApp 0xb809fb15 0xb8000000 + 654101 4   LaunchCFMApp 0xb80bd72e 0xb8000000 + 775982 5   LaunchCFMApp 0xb811eb4e spin_lock_wrapper + 3852
Unknown thread crashed with i386 Thread State: eax: 0x00000018  ebx: 0xb80a5628  ecx:0x00000000  edx: 0x00000003 edi: 0x00000018  esi: 0x80d03990  ebp:0xb7fff9f8  esp: 0xb7fff9c0  ss: 0x0000001f  efl: 0x00010206  eip:0xb80a564f   cs: 0x00000017  ds: 0x0000001f   es: 0x0000001f   fs:0x00000000   gs: 0x00000037 -----
Please help! Our team has been working on this document for months, and it would be a shame if it is lost.
  • 11 more comments
  • melissa_rama Jan 26, 2009
    Report Version: 4
    Please help! I understand that there is recovery software out there, but is there a way to 'recover' this file without software? And how can this be prevented in the future (aside from creating a backup file)?
    I've had other members of the team try to open the file on their computers, but it doesn't work. Or copying the file from the server onto our desktop, but that doesn't work either.
    Luckily we do have earlier version of this document saved. A lot of work will need to be redone though.
    I just wish I knew what happened so that it can be prevented in the future... it's just so frustrating...
    If it is a virus, then I'm even more confused. Wouldn't a virus need to introduced from an outside source? No? I don't understand how a document can all of a sudden catch a virus...
    machadojr_fe
    Rank: Guru
    Rating: 86%, 69 votes
    please open excel then from within excel click open and then find the file and click the black arrow next to open and select open and repair. Please let me know what happens when you try this.
    --- I wasn't able to do this because there is no 'open and repair' option. The options I was given was opening original, copy or read-only.
    MNfisherman
    Rank: Wiz
    Rating: 83%, 47 votes
    To manually repair a file
    On the File menu, click Open.
    In the Open dialog box, select the file you want to open, and click the arrow next to the Open button.
    Click Open and Repair, and then choose which method you want to use to recover your workbook.
    OTHER WAYS TO OPEN THE FILE
    Start Excel and open a blank workbook if one is not open on the screen.
    On the Tools menu, click Options.
    Click the Calculation tab.
    In the Calculation section, click Manual, and then click OK.
    On the File menu, click Open and try to open the file.
    OR
    On the File menu, click Open. Then, browse from the current folder to the folder that contains the damaged file, and click Cancel.
    Click New on the File menu, click File, and then click OK.
    Type =File Name!A1 in cell A1 of the new workbook, where File Name is the name of the damaged workbook. If the Select Sheet dialog box appears, select the appropriate sheet, and click OK.
    Select cell A1, and on the Edit menu, click Edit. Then, select an area that is approximately the same size as the range of cells that contain data in the damaged file, and then click Paste on the Edit menu.
    With the range of cells still selected, click Copy on the Edit menu.
    On the Edit menu, click Paste Special, select Values, and click OK.
    OR
    If you have the Microsoft Excel converter installed, you might be able to open your Excel workbook in Microsoft Word. If the file does open in Word, you will not be able to recover module sheets, dialog sheets, chart sheets, macro sheets, or any embedded charts. Also, you will not recover any cell formulas, only the results of those formulas that are currently in the cells.
    You can also open your Excel workbook in WordPad. If the file does open, you might recover Microsoft Visual Basic code in your modules and class modules. Search for the words "Sub" or "Function" to find your code.
    OR
    If you have Microsoft Excel Viewer installed, you may be able to open the Microsoft Excel workbook in Microsoft Excel Viewer, copy the cells, and paste the cells into a new workbook. However, you cannot recover module sheets, dialog sheets, chart sheets, or macro sheets. Also, you will not recover any cell formulas, only the results of those formulas that are currently in the cells.
    To download Excel Viewer 2003, or for more information, see Downloads on Microsoft Office Online.
    OR
    Enter the following macro code in a module sheet: Sub GetChartValues97()
    Dim NumberOfRows As Integer
    Dim X As Object
    Counter = 2
    ' Calculate the number of rows of data.
    NumberOfRows = UBound(ActiveChart.SeriesCollection(1).Values)
    Worksheets("ChartData").Cells(1, 1) = "X Values"
    ' Write x-axis values to worksheet.
    With Worksheets("ChartData")
    .Range(.Cells(2, 1), _
    .Cells(NumberOfRows + 1, 1)) = _
    Application.Transpose(ActiveChart.SeriesCollection(1).XValues)
    End With
    ' Loop through all series in the chart and write their values to
    ' the worksheet.
    For Each X In ActiveChart.SeriesCollection
    Worksheets("ChartData").Cells(1, Counter) = X.Name
    .Range(.Cells(2, Counter), _
    .Cells(NumberOfRows + 1, Counter)) = _
    Application.Transpose(X.Values)
    End With
    Counter = Counter + 1
    Next
    End Sub
    Insert a new worksheet into your workbook and rename it ChartData.
    Select the chart from which you want to extract the underlying data values. Note The chart can either be embedded on a worksheet or on a separate chart sheet.
    Run the GetChartValues97 macro.The data from the chart will be placed in the ChartData worksheet.
    --- I couldn't do the first couple of options because the commands were not available in Excel (I have Excel for Mac). I want to try the macro code you have provided, but I'm not sure how to do it.
    WebDoc666
    Rank: Wiz
    Rating: 79%, 55 votes
    post it some where and give the link and i will open it for u
    --- Even if I knew how to do that (post it and provide the link), I couldn't, because it is an internal corporate document (confidentiality).
    rylee_smith
    Rank: Wiz
    Rating: 81%, 46 votes
    Hi
    I think the file got corrupted due to virus or a macros error. Try restoring the system to the date when the file was running fine. You can restore the system by clicking on start menu>programs>accessories>system tools>system restore.
    When you click on the system restore it will ask you to restore the system to previous date, choose the date when the file was running fine.
    Before doing a system restore back up all your data as it might get deleted. Also make a copy of this excel file somewhere else before system restore.
    Ask for any assistance.
    Thanks
    Rylee
    --- Our office operates on Macs, so that command can't be followed
    frcs68
    Rank: Wiz
    Rating: 82%, 442 votes
    is the excel file link to other excel file or is it link to other database.
    in looking throught the error, seems like the database is corrupted. either SQL or MS Access.
    the excel worksheet will not connect if the link is broken, or the data can't be retrieved due to corrupted data.
    you need to talk to the IT department and have them rebuild the database server.
    --- the excel file is linked to other excel or word files. I'm not sure what SQL is, but nothing is linked to MS Access (we don't have that application). When the message window appears - asking to either ignore or fix links - is there no way to fix the links then? I tried, but obviously I don't know what I'm doing because the excel file still won't open...
    machadojr_fe
    Rank: Guru
    Rating: 85%, 70 votes
    Comment posted on Jan 26, 2009
    please try with read only and see if it opens
    --- the file will not open in 'read-only' mode
    P3NGYJ03
    Rank: Wiz
    Rating: 72%, 24 votes
    Hello and welcome to FixYa!,
    Have you tried a Clean Install of Excel- It May be a Corrupted file in Excel causing this
    If not send the File to Jackson-h@hotmail.com and i will Scan for viruses and try to Open
    I'm using Excel 2003 for Windows XP
    Hope this helps --P3NGYJ03
    --- Do you mean re-install excel and then try opening it? I could try that if nothing else works.
  • melissa_rama Jan 27, 2009
    machadojr_fe
    Rank: Guru
    Rating: 86%, 71 votes
    Click here
    Please try this and let me know if it helps
    --- those excel add ins look great, but when I followed the demands, I discovered that those add-ins are not available on our system
    Comment posted on Jan 27, 2009
    could you please let us know what type of systems you are using so we can try and provide you more useful help
    also please try this
    Open Excel, go to Tools=>Options=>General tab and make sure Ignore Other Applications is not checked.
    Please post the results
    ---- We are using MS Excel 2004 on Macs, not a PC environment
    Novelist:
  • 123 Answers
Kernel Protection failure is caused when a program/hardware driver tries to access memory that is already in use by the operating system and is thus protected, causing the offending program/driver to crash.
Did you install any new hardware prior to the crashing? if so uninstall it & the drivers and try again.
Unless someone reprogrammed your excel macros to use memory that is protected -not a very easy thing to do so thats unlikely-
do you have another machine to copy your excel file to and try? thats a good way to see if its a driver fault, as it will not replicate the error usually.
My guess is that the spreadsheet is recoverable.
If you can e-mail the file to me I can have a look at it here. I understand that it may contain sensitive data and u may not want to do that....I also realise that your macros may not run on a different machine but it helps to identify the origin of the error.
Hope this helps a lil...
Posted on Jan 27, 2009
    Sergeant:
  • 320 Answers
With Excel closed, try re-registering Excel in Windows by
clicking on Start | Run | Open: excel /unregserver | OK | Open:
excel /regserver | OK.
Or click on the below link and try those... Might work.
http://www.officearticles.com/misc/files_dont_open_when_double-clicked_in_microsoft_office.htm
Thank you......
  • Microsoft Master
  • 19,396 Answers
The file does not open because it is damaged.
It it is not a matter of enabling or disabling Macros.
When you work on a file at programming level you should always save a backup.
All you can do is trying one of the following recovery tools, and cross your fingers:
Excel Recovery Tool
Recovery for Excel
Repair Excel File
Excel Recovery Software
Excel File Recovery and Date Tools
MS Excel file Recovery Software
Excel recovery toolbox
Excel recovery ExcelFIX
Excel recovery Software
How To Get Fix Full Version | Excel File Recovery
  • 50 Answers
Try a nod32 anti virus system and see if that works
  • 104 Answers
Normally when macro-enabling window box pops up at any MS-Office Applications, it means there is Unstable Program Code in your MS-Office Application.
You can resolve this error by installing a clean MS-Office or a new installation of a newer version (eg. Office 2007)
Best Regards
Van
Posted on Jan 26, 2009
  • 741 Answers
Your file is corrupt with a virus or from broken links. the correct answer is to load your backup or call computer repair, or your IT guy to look at it.
  • 86 Answers
Do you use some kind of CVS? for managing changes to the file?
if so you can compare versions to find out what really happen.
in the case of a corrupted file there are Excel Recovery Tools for this, either free or paid. use a search engine to find one that fits your needs
  • Dr_Joseph
    Dr_Joseph Jan 26, 2009
    Let me explain better what CVS is. Any changes to files are transparently saved in a repository. you still keep it simple, but other functionalities are provided, such as history of versions, versions comparison, comments, and reverting to a previous version, to name a few.
    You can work directly from the repository and it acts just like windows explorer.
    This is a great option so you will not have the same problem again, and without having to do backups of data.
    There are few options to this but i can recommend Visual Source Safe as a reliable and easy to use tool.
  • 177 Answers
  • Jackson Henney Jan 26, 2009
    That is Exactly What i'm Saying
    Can you send the File Anyway
    JACKSON-H@HOTMAIL.COM
    --BYE
  • Microsoft Master
  • 4,806 Answers
Hi there
I'm having Deja-vu with this one
Please send me the file to work with ............. leecom72@hotmail.com
Regards
    Genius:
  • 1,605 Answers
Is the excel file link to other excel file or is it link to other database.
  • Frank
    Frank Jan 27, 2009
    the excel file will not work unless the SQL database is fixed. the link from excel is looking for the data that are stored in the SQL server and the link to certain file.
    Since the SQL server is no-functional, the link is broken, there for you get the fix link error. regardless what you do is is not going to be fix till teh SQL server is functional.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks
Rylee
  • 565 Answers
Post it some where and give the link and i will open it for u
  • 11,896 Answers
  1. On the File menu, click Open.
  2. In the Open dialog box, select the file you want to open, and click the arrow next to the Open button.
  3. Click Open and Repair, and then choose which method you want to use to recover your workbook.
  1. Start Excel and open a blank workbook if one is not open on the screen.
  2. On the Tools menu, click Options.
  3. Click the Calculation tab.
  4. In the Calculation section, click Manual, and then click OK.
  5. On the File menu, click Open and try to open the file.
OR
  1. On the File menu, click Open. Then, browse from the current folder to the folder that contains the damaged file, and click Cancel.
  2. Click New on the File menu, click File, and then click OK.
  3. Type =File Name!A1 in cell A1 of the new workbook, where File Name is the name of the damaged workbook. If the Select Sheet dialog box appears, select the appropriate sheet, and click OK.
  4. Select cell A1, and on the Edit menu, click Edit. Then, select an area that is approximately the same size as the range of cells that contain data in the damaged file, and then click Paste on the Edit menu.
  5. With the range of cells still selected, click Copy on the Edit menu.
  6. On the Edit menu, click Paste Special, select Values, and click OK.
OR
OR
OR
  1. Enter the following macro code in a module sheet: Sub GetChartValues97()
    Dim X As Object
    Counter = 2
    End With
    ' the worksheet.
    End With
    Next
    End Sub
  2. Insert a new worksheet into your workbook and rename it ChartData.
  3. Select the chart from which you want to extract the underlying data values. Note The chart can either be embedded on a worksheet or on a separate chart sheet.
  4. Run the GetChartValues97 macro.The data from the chart will be placed in the ChartData worksheet.
  • 9 more comments
  • Nate Stansfield
    Nate Stansfield Jan 26, 2009
    IF YOU NEED MORE INFO: (copy and paste this link in your browser)
    http://www.google.com/search?q=excel+fil...
  • Nate Stansfield
    TRY THIS:
    Tools,
    Options, and in the
    >General tab, de-select the option "Ignore other applications."
    OR
    To resolve
    this issue in Office 2007 Click on the Orb, and then click on "Excel
    Options", Select Advanced on the left hand side, on the right hand side
    remove the check mark from "Ignore other applications that use dynamic data exchange".
  • Nate Stansfield
    you can also use QuickLook to at least see what is inside a Excel file.
  • Nate Stansfield
    openoffice.org also opens excel documents
    I've had great success with corrupt files using
    OpenOffice. The most convenient version is the free NeoOffice/J which
    you can get here:
    http://www.neooffice.org/
  • Nate Stansfield
    Nate Stansfield Jan 27, 2009
    How to Create a Personal Macro Workbook
    loadTOCNode(2, 'moreinformation');
    The easiest way to create a Personal Macro Workbook is to record a "dummy" macro. To do this, follow these steps:
    1. Start Excel so that only a new workbook is open. On the Tools menu, point to Macro, and then click Record New Macro.
    2. In the Record Macro dialog box, click Personal Macro Workbook in the Store macro in list.
    3. Click OK. Because you are creating a "dummy" macro, do not click or type anything.
    4. In the toolbar that appears, click the Stop Recording button.
    5. On the Excel menu, click Quit. Or, for versions of Excel earlier than Excel X, click Quit on the File menu.
    6. Click Save when you are prompted to save your changes.
    When you start Excel, this Personal Macro Workbook opens as a hidden
    workbook. By default, it is stored in the following path, depending on
    your version of Excel.
    In Excel 98 and in Excel 2001
    Microsoft Office folder:Office:Startup:Excel:Personal Macro Workbook
    In Excel X or in later versions
    Hard disk drive:Applications:Microsoft Office version:Office:Startup:Excel:Personal Macro Workbook
    Back to the top
    How to Use a Personal Macro Workbook
    To write or edit VBA code in a Personal Macro Workbook, follow these steps:
    1. On the Tools menu, point to Macro, and then click Visual Basic Editor.
    2. In the "Project - VBA Project" window, double-click VBAProject (Personal Macro Workbook) to display the Modules folder within.
    3. Double-click the Modules folder to display any modules in this project, and double-click a module to display its code or blank code sheet.
      You can use this code sheet to write and edit VBA code.
  • Nate Stansfield
    THIS SOLUTION WORKED FOR ANOTHER PERSON WITH YOUR SAME PROBLEM:
    First try the standard fix(es)......Tools>Options>General uncheck "ignore
    other applications
    OR Re-register Excel.
    Start>Run "excel.exe /regserver"(no quotes and note the space before the /
    mark).
    You may have to enter your full path to excel.exe....in that case surround
    with quotes as in..... "C:\mypath\to Excel\somewhere\excel.exe" /regserver
    In your case it sounds more like re-registering first would be best.
  • Nate Stansfield
    ANOTHER OPTION IS TO TRY:
    you can download a hex-reader from PepiMK's website (Spybot S&D).
    The download you want is FileAlyzer. This should allow you to at least
    recover the latest information in the file and record it to one of your
    backups. Might involve a bunch of typing however.
    http://spybot.safer-networking.de/in...g...
    This one looks even better, but I haven't tried it.
    It fixes Excel spreadsheets.
    Download the free demo from here:
    http://www.officerecovery.com/excel/
  • Nate Stansfield
    ALSO YOU MUST HAVE EXCEL 2004 COMPLETELY UPDATED AS WELL AS YOUR OPERATING SYSTEM.
    > The OS is version 10.5.6, which is the most current update. Apologies for
    > forgetting to include that!
    > I'm don't think it's a permissions problem. The issue is persistent across
    > accounts. I did repair disk permissions through Disk Utility, but the issue
    > still exist. I believe the user does have necessary permissions to open these
    > files, as they work just fine if Excel is left at version 11.0.0 rather than
    > 11.5.3 or the they are opened with Apple Numbers or OpenOffice.
    > Workbooks will not open even if done through File => Open, nor will they open
    > if Excel is launched while holding the Shift key.
    > I did check the error logs in Console and the following appears whenever I
    > try to open one of the problematic workbooks:
    > [339] kCGErrorIllegalArgument: CGXGetWindowWorkspace: invalid window id: 6c
    > Other window ID's have been 40, 4a, and 75, if that makes a difference.
    While starting XL with the shift key down SHOULD prevent preference
    corruption from occurring, the first thing I'd try is, with ALL Office
    apps closed, deleting or renaming any
    com.microsoft.*
    files and the Microsoft folder in ~:Library:Preferences (where ~ is the
    home directory).
    Next, I'd try creating a fresh user account and seeing if the problem
    persisted. If it doesn't, some other app/haxie is interacting with XL in
    your user's account.
    If this happens in a fresh user account, too, I'd try round-tripping a
    couple of workbooks through XML/Web Page format to see if it's workbook
    corruption issue.
  • Nate Stansfield
    If the file extension is a dBASE II/-IV file type. Since that application was never
    produced for Mac the file type is not registered in Mac OS & therefore isn't
    a recognized/supported file type.
    As another poster responded, Mac Excel _may_ be able to open the file if you
    set the Enable: option to All Documents. However, even PC Excel can't open
    *all* .dbf files - there are a number of variables that come into play.
    Interestingly enough, when you save the file the Save As dialog's Format:
    list *does* provide a choice of dBASE formats from which to choose - among
    others that aren't specifically listed in the Open dialog's Enable: list:-)
  • Nate Stansfield
    IF YOU DON'T HAVE AN EXCEL 2004 USERS MANUAL (copy and paste this link in your browser)
    http://books.google.com/books?id=PlBJ4rI...
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    HERE IS SOME LINKS ON SQL SERVER LINK REPAIRS"
    http://msdn.microsohttp://stackoverflow....
    Link to SQL Server Database-us/library/ms188
    How to use Excel with SQL Server linked servers and distributed ...279.aspx
    How to create a SQL Server linked server to DB2
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Check out your micro file is in right place in vb editor
it is in same project where the excel files are
  • yashan.co.in Jan 26, 2009
    its stop updating it and work fine.
  • 916 Answers
Please open excel then from within excel click open and then find the file and click the black arrow next to open and select open and repair. Please let me know what happens when you try this.
  • 2 more comments
  • machadojr_fe Jan 26, 2009
    Click here
  • machadojr_fe Jan 27, 2009
  • 112 Answers
I am taking a guess at a virus or a bad sector on the hard drive.
Do you not have a backup program? You could restore it to it`s previous operating state.
It`s trying to open but not being recognized past the first sector.
If it is a virus or dreaded (worm), then it will embed itself deeper the more you try to open it.
Hope this helps.
  • 3,940 Answers
#1 ensure that this document has the same issues on another system. If it does, the file is definitely the issue.
#2 Scan the document for viruses/spyware and see if it can be repaired if infected.
#3 Check with your team, see if anyone was pessimistic enough to create a backup of the file.
The research I was able to do didn't give any solution to fixing the document only trying to duplicate the issue with another file
  • Microsoft Master
  • 13,433 Answers
If the document doens't open on any computer, the file is corrupt
there are recovery software you can try such as
http://www.excelfilerecovery.com/
Please from now on, take a backup of the file and store it at another location so incase this happens again you will have a backup to restore and continue from.
  • Ekse Jan 26, 2009
    Take dayly or half day backups of the file and store them.
SOURCE: Excel Macro
Try these links you could find out
http://www.vbaexpress.com/kb/getarticle.php?kb_id=706
http://www.computing.net/programming/wwwboard/forum/5902.html
Posted on Dec 17, 2007
mcc99
  • 51 Answers
SOURCE: Macros Help PLZ
Change the file ending back to .xls, open the file, enable macros, then try renaming the file to the new extension.
Posted on Mar 15, 2008
  • 26 Answers
SOURCE: MS EXCEL 2000 corrupted workbooks/worksheets
it sounds like you are going over the limits of the program these are the specs. I would recommend dividing up the data if you can. or moving it to a database that can act like excel and hold more data.
Posted on Apr 29, 2008
  • 67 Answers
SOURCE: Macros
After you record your macro do the following.
Open the excel file contains the macro. Go to tools and go to macro and click on macros. Select the macro you wish to add the close operation. Click on Step into... This will open up the visual basic editor. In the code window, at the bottom row you will see End Sub. Right before that row, type workbooks.close
Save the macro by clicking the save button. And you can run your macro to see if it works. I tried, it does :) Good Luck :)
Posted on Feb 24, 2009
  • 67 Answers
SOURCE: tools protect workbook& sheet
Open the protected sheet... Go to edit and click select all. Go back to edit and click on copy. Open a new excel sheet, go to edit and click on paste. Now you have the copy of the protected sheet without the protection.
Posted on Feb 25, 2009
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Feb 21, 2014 | Microsoft Excel for PC
Hi Team, I have created macro in MS Excel2007 and after executing macro output file will be created MS Excel2003. Once MS Excel2003 file closed and reopen all the formating lost. How can overcome this...
It is unlikely that you can really overcome this as Office 2003 and Office 2007 have completely different file formats and structures. But if you output it to an Office 2007 file and use the Microsoft converter for Office 2003 than it may work. The converter can be found here
Jun 22, 2011 | Microsoft Excel 2007 0882224152648 Full...
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
How i can crack the password of excel sheet..............
Have tried downloading the password.xla? If not, below is the link:
http://www.straxx.com/excel/password.html
Just add this xla to your addins and then open your excel document. The sheet will be automatically be unprotected.
Feb 09, 2011 | Microsoft Office Professional 2007 Full...
Help: excel 2007 suddenly hangs when working with macros
check the physical memory,and also if the excel file size,if the file size is so big then it gets hang
thanks
Feb 17, 2010 | Computers & Internet
Whenever I open a new spreadsheet now it automatically opens up a spreadsheet calles PERSONAL. Why is that and how can I get rid of it... I think it started after a did a macro but I am not sure. Thanks,...
You're right - it was caused by recording a macro. When you record a macro you are given the option to store the new macro in "This Workbook", a "New Workbook" (the default), or in a "Personal Macro Workbook". It looks like you selected "Personal Macro Workbook".
The recorded macro is stored in a special workbook called "Personal.xls". This workbook is loaded every time Excel is loaded. If you don't want this workbook loaded, then just delete it or rename it.
The file is buried deep in Microsoft's application data area. On my Vista computer it's in C:\Users\frogfund\AppData\Roaming\Microsoft\Excel\XLSTART On my Windows XP computer it's in C:\Documents and Settings\frogfund\Application Data\Microsoft\Excel\XLSTART. Depending on your computer your Personal.xls might be in a slightly different location. You might need to do a search using Windows Explorer.
If you are still having troubles finding personal.xls 1. Open Excel, 2. Open the Visual Basic editor (hit Alt-F11 or click Tools-Macro-Visual Basic Editor) 3. Click Tools-References to bring up the references dialog 4. Click on VBAProject in the list. The file location will be displayed near the bottom of the dialog box. Sometimes this might be cut off at the end, but it should give you a good idea where the file is located. 5. Click Cancel to close the dialog.
Sep 23, 2009 | Microsoft Office Excel 2003 for PC
While using Execl , we are getting compatibility
.xls files opened in Excel 2007 is "always" in "Compatibility Mode" since default 2007 excel files have .xlsx extensions
Sep 16, 2009 | Microsoft Office Professional 2007 Full...
Macros
Aug 18, 2008 | Microsoft Excel for PC
Macros Command Help
Your Excel may have a different "Macro Security" setting. Your "Macro Security" can be adjusted: Tools, Macro, Security. I highly recommend the "Medium" setting. This will prompt you when an Excel file is opened that contains Macros to Enable or Disable. If you choose a security setting of "Low" please be very careful as this will allow Macros to run without any notice, VERY DANGEROUS.
Oct 04, 2007 | Microsoft Office Standard for PC
Microsoft EXCEL 2004 for Mac Logo
180 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
