Question about Viamichelin X-950T 4.3" Sat Nav With Europe Maps, Traffic Updates And Integrated Michelin Guide
Install android on viamichelin device - Viamichelin X-950T 4.3" Sat Nav With Europe Maps, Traffic Updates And Integrated Michelin Guide
My android is no longer supported by google play
There are alternative ways to download and install applications on an android mobile device without referring to "Google Play". Android application files are usually .apk files. For the case of actually downloading and installing Google Play, just search for "Google Play apk" file. Sites like "APK4Fun" have most common android application files available open to download. But using .apk files from sources other than "Google Play" isn't always a secure thing to do, so choose at your discretion. If you are having problems installing the application or even downloading it, try a PC android device manager like "MobileGo" by Wondershare. Install the application on your PC and via USB connect your android device to the PC. Make sure USB Debugging is enabled on your device and the device is sync with the PC and not just charging. Once the MobileGo program identifies your android device you can install .apk files to your android device via PC by choosing install app and finding the .apk file on you downloaded on your computer.
Sep 28, 2016 | Generic MID8125-4G Coby Kyros 8"...
Restart a tablet when it is locked
  • Connect the tablet with USB cable to the PC
  • Open the command prompt
  • Change directory to the android SDK platform tools (Type in cmd--> cd C:\Program Files\Android\android-sdk\platform-tools)
Type following commands in cmd
  • adb devices (verify device is identified by pc. If not reconnect device and try again)
  • adb shell
  • adb reboot
It will restart.
Feb 12, 2014 | Android 4.0 Tablet PC
Install
You mean you want to install android in your device? Android devices already come with the software already preinstalled in them so you dont need to do any installation again rather the only thing you can do is to upgrade the operating system. Hope it helps
May 06, 2013 | HTC F3188 Smartphone
Windows 7 michelin satnav
Unless the program was designed for Windows 7 it will not work, you must update to the newer version designed for 7
Nov 05, 2012 | Viamichelin X-950T 4.3" Sat Nav With...
950t. is frozen in a loop. Via michelin screen to please wait then back to vm screen. Done soft and hard reset. Content manager can't see the device.
hi there<br /> im havingthe same poblem with my vm 960, did u manage to rectify this and if so how?<br /> <br /> many thanks in advance<!-- from fixya rte -->
Feb 08, 2010 | SNK ViaMichelin Handheld GPS Receiver
Touchscreen broken.a shop to repair it?
found ashop in the Netherlands who will replace the touchscreen.Spark Electronics
Nov 08, 2009 | SNK ViaMichelin Handheld GPS Receiver
Via michelin x960 has jammed up.only a please wait
hi<br /> im experiencing the same problem, did u manage to rectify it and if so could u pls share it with me.<br /> many thanks<!-- from fixya rte -->
Jun 08, 2009 | SNK ViaMichelin Handheld GPS Receiver
Buttons and screen not responding on via michelin x-950t sat nav
stick a pin in the reset hole in the back.that should fix the problem.
Mar 01, 2009 | SNK ViaMichelin Handheld GPS Receiver
Lost info on sd card
i lost the map on my sd card for my viamichelin x-930
Aug 09, 2008 | GPS
Viamichelin X-950T 4.3" Sat Nav With Europe Maps, Traffic Updates And Integrated Michelin Guide Logo
29 people viewed this question
Top Viamichelin GPS Experts
Are you a Viamichelin GPS Expert? Answer questions, earn points and help others
