Question about Yamaha RX-V650 Receiver
Yamaha rx-v630 won't power on. Only clicks
  • 7 Answers
SOURCE: Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Posted on Jun 05, 2007
SOURCE: Yamaha RX-V1 Power
Got the same problem and did some searching.
Strange thing is that next day the amp works fine.
This is what I found on http://www.forums.hcsd.com.au/Blah.pl?m-1210733289/s-8/
SYMPTOM: The power cannot be turned on, or the protection circuit is activated to turn off the power.
CAUSE: Fluid leakage occurs from the backup capacitor C633 0.047F 5.5V (C662 in the case of RX-V3000/DSP-AX2) on the Function PCB and causes a short with the adjacent components and between patterns, resulting in operation of the protection circuit. Fluid leakage tends to occur with this capacitor particularly with high internal cabinet temperatures, with or without the power on. Often, the leakage is only visible with very careful inspection.
SOLUTION: Two types of backup capacitors are now available with a longer expected service life. When servicing, thoroughly clean the leaked fluid from the PCB and from under any nearby components before replacing the capacitor. There are models other than those mentioned above that use the subject backup capacitor. Check them for fluid leakage and replace the capacitor as needed.
PART(S): Old
Ref. No. Part No. Description Remarks
C633 or
C662
VT740700
V3860300 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* VU545000 ELECTROLYTIC CAP 0.047F/5.5V
Horizontal type
New
C633 or
C662 WD294400 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* WD292000 ELECTROLYTIC CAP 0.047F/5.5V Horizontal type
Posted on Jun 24, 2008
SOURCE: Yamaha RX-V630 Doesn't power on!
I have the same problem.
Posted on Sep 04, 2008
  • 165 Answers
SOURCE: yamaha rv1000
ok yu problem has to be with the protection system before you burn it up it collapses to protect the whole system.....go direc to the thermal cut off devices on the main output and then to the power system......
Posted on Nov 17, 2008
SOURCE: yamaha av receiver rx-359
go to best buy and buy a new recever
Posted on Apr 10, 2009
How to connect a turntable to Yamaha Rx-v630
If your turn table has a ground wire with the R and L wires then you can not connect it to this receiver. Unless you have a switch on the turn table that chooses between internal or external amp. If you have the switch, pick external amp and then run your R and L into your TV/CD input. Good luck to you.
Jun 06, 2016 | Yamaha RX-V630 Receiver
How do I hook up an equalizer to my Yamaha RX-V630 Receiver ?
you hook it up through your tape monator just like you were hooking a tape deck up if you have a tape deck pluged in there you should be able to plug it in to the back of equalizer the same way
Sep 08, 2014 | Yamaha RX-V630 Receiver
Yamaha rx-v630 in silent mode without headset plug into it
either the headphone jack is bad, or the cable from the headphone pcb is disconnected. Look inside the unit and follow the cable from the headphone board and make sure it is plugged into the main pcb.
Jan 02, 2013 | Yamaha Audio Players & Recorders
Just clicks no power. Already checked for touching wires and proper cooling. This unit has worked fin in the same location for four years. Any other ideas?
I had a similar 'drop out' problem with my Yamaha RX-V3300.
Problem- Possibly loose speaker connections.
I have banana connections which I unplugged; tightened speaker terminal connections at back of receiver and then reinserted banana speaker connectors- which remedied problem. There is possibly some kind of loose connection either caused by the banana plugs or at speaker connectors at the back of the receiver, which was remedied (i.e. possibly temporarily) by reinserting the banana plugs.
I also previously thought something was wrong with the main on/off power relay which was 'dropping out' and replaced it, but then 'drop out' problem returned a few days later. I reinserted and tightened speaker connectors, which has it working again.
Dec 22, 2009 | Yamaha RX-V630 Receiver
Yamaha RX-V630 Is not responding to the remote control unit
Replace the remote control with a universal remote (e.g. Logitech). It is more advanced and very user friendly with a help function if anything doesn't work.
Just follow the instructions in the unit's manual.
If you drop it; be sure to replace the batteries correctly.
Keep good batteries in it and enjoy the convenience of only one remote.
If still in trouble; just visit your local Yamaha dealer for help.
Jul 11, 2009 | Yamaha RX-V630 Receiver
YAMAHA RX-V630 WON'T POWER ON NO CLICKS
If the unit is like the Rx-570 , the display bulbs have quit.
Theyre 14 volt lamps about 0.1 wide x 0.250 long (white wire leads)
Located in the plastic shroud behind the display
Mar 23, 2009 | Audio Players & Recorders
Los receivers traen un transformador este trae un fusible termico quizas este dañado por eso no enciende.O los amplificadores de audio estan dañados checa desoldandolos.
Apr 04, 2008 | Yamaha RX-V630 Receiver
Jun 05, 2007 | Yamaha RX-V630 Receiver
Yahama receiver Rx-630 not working
The problem might be caused by two major circumstances. 1)Touching wires 2)Overheating. I suggest you unplug all wires connected to the amp then turn on the amp. If it gets turned on then we know that the problem is that you have touching wires. If there is a short circuit somewhere, get rid of it. The ventilation is another important issue that you have to pay attention. It simply causes overheating.
Yamaha RX-V650 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
