Question about KitchenAid Bosch 27 in. Double Wall Oven Blender
Bosch double wall oven HBN 64 latch jammed.door will not open
After using self clean on the top built- in Bosch oven for the first time in 6 years, the locking latch will not release & door will not open.  (Previously, the door would not close properly which meant a very long pre heat).
  • 1,550 Answers
The door latch assembly is defective.
You need to replace the assembly as a whole.
Thats the only solution to this problem .
Posted on Jan 26, 2009
I have the Bosch blender and the dial doesn't seem to work it is just flashing red light. I have only used this blender once. So frustrating
Immediatly return it to your dealer if the user manual give no suggestions.
Can be an armature/field problem
Oct 18, 2016 | Bosch Blenders
Jug for a Breville Blend Master modelBLR- 3
Call the manufactor or e-mail the company they'll have it.
Jan 10, 2013 | Bosch MMB2000 Work Top Blender
I broke something when I was putting the jar on my bosch MMB1000 blender and then it didn't start after that. I thought that I had broken the safety and when I open it up I saw a small broken plastic thing...
Without seeing the part that is broken it is hard to say what exactly the problem is. But it sounds like it is one of the safeties. Look on the bottom of the jar to see if you can see where the plastic broke off of. If not then the plastic is probably the safety inside of the lower part of the unit.
Jan 07, 2011 | Bosch MMB1000 Work Top Blender
Oven appears to remain on after the baking process is finished. It is a brand new Frigidaire double oven and we have just used it for the first time.
What is staying on? If you are hearing a fan staying on, don't worry about it. Some ovens have a cooling fan that continues to run until the oven cools down below a certain temperature.
Dec 22, 2009 | Blenders
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Glass jar replacement
Sorry we neither sell part or have any way to locate them.
Jul 10, 2017 | Bosch MMB2000 Work Top Blender
I want to replace plastic jug of my blender, It leaks
Dec 09, 2007 | Bosch MMB2000 Work Top Blender
Replacement glass jug?
I will buy the blade set from you? I will return....
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
The plastic base of the glass jug is broken, need repacement.
I used a 4" stainless steel hose clamp as ours was cracked but not in pieces. So far it has worked.
Nov 11, 2007 | Bosch MMB2000 Work Top Blender
KitchenAid Bosch 27 in. Double Wall Oven Blender Logo
60 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
