Question about Brother MFC-8460N All-In-One Printer
My screen says pc fax msg: 009 and I cant get it to print them.
Help
Problem solved: Hit menu, 253,start key.
Posted on Jan 27, 2009
Cant fax, getting a msg "check scan.platform" Thank you, Z
When you remove plastic cover, wich is above paper cass. you will be able to see long black plastic with white scanner section.In the midlle is handle.
You need to open and very vell close it - THIS IS SCANING PLATFORM.
If does not help you have problem with main pcb.
Jun 15, 2010 | Canon L120 Fax Laser Printer
What button do I press to generate a Fax report - this is not always generated automatically.
Sounds like your Fax Options are set to print on error only. If you want to have both confirmations and error pages do the following:
1 Press Menu until “Fax Setup” appears on the top line of the display. Press Enter.
2 Use the scroll button to find MSG Confirm. Press enter.
3 It may be selected to On-Err. Use the scroll arrow buttons to get to On. Press Enter.
4 To return to Standby mode, press Stop/Clear.
This should make your fax print out a confirmation on a successful or failure transmit of your fax.
If you want to print out the last few sent or receive faxes:
Printing a Report
1 Press Menu until “Reports” appears on the top line of the display.
2 Press the scroll arrow buttons to display the report or list you want to print on the bottom line.
•Phone Book: Phonebook list •Sent Report: Sent fax report •RCV Report: Received fax report •System Data: System data list •Scheduled Jobs: Scheduled job information •MSG Confirm: Message confirmation •Junk Fax List: Junk fax number list
3 Press Enter. The selected information prints out.
You can find your manual in English by clicking here.
------------------------------------------------------ Please rate this post if it helps you! :)
Dec 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I have Panasonic KX-FL612 fax machine , the paper gets jammed and the fax is saved in memory . when i release the jammed paper I can not print the fax in memory . How can I print the fax in memory ?
when fax gives msg ,fax in memory,just remove jammed paper .put fresh papers in tray.if the msg is coming on screen that fax in memory just press START key.there is a green button labeled as fax start .u will receive all faxes in memory.MIAN AKHLAQ .do not forget to rate the solution.
May 13, 2009 | Panasonic Office Equipment & Supplies
Cannot get messages out of memory
We switch our off, wait 10 seconds, switch on & fax is printed. We don't think we have lost any faxes this way but be aware it might happen.
Jan 29, 2009 | OKIFAX 4580 Plain Paper LED Fax
Pixma printer mp780 cant print, saids on screen "wrong cartridge"
hi, your print head is blocked qy6-009-000, you can clean them or replace them
Dec 08, 2008 | Canon PIXMA MP620 All-In-One InkJet...
How do I print off fax in memory Panasonic model no KX-FP215E?
when msg is displaying on screen fax in memory .install paper and press fax start key.all faxes in memory will bi print.by mian jee
Dec 02, 2008 | Panasonic KX-FPG378 Fax
Panasonic DP 180 - will not print faxes
you need to do an all job clear in fax mode. leave me a msg and i will try to help
Oct 04, 2008 | Panasonic Workio DP-190 Multifunction...
Can not print fax in Memory
Bad news. Check paper and ink supply. SORRY.
Sep 19, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Pc fax msg
The display msg means that there are a few faxes in storage and they just need to be printed from the memory:
on my mfc-7440n:
Printing a fax from the
memory 6
If you are using the Fax Storage feature
(Menu, 2, 5, 1), you can still print a fax from
the memory when you are at your machine.
a Press Menu, 2, 5, 3.
Remote Fax Opt
3.Print Fax
b Press Start.
c Press Stop/Exit.
Aug 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Ready Memory Received
Dear guys, your toner cartridge is low and as a preventive measure, the unit stores the faxes in order to give priority to copying and printing. If you are using remanufactured cartridges, the unit might not be displaying the low toner warning.
Jan 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Brother MFC-8460N All-In-One Printer Logo
129 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
