Question about Linksys Wireless-G WRT54G Router
Printing to a network via wireless router
I can print to all of the printers on our network when the cable is plugged directly into my computer. However if I am using a wirless router I can't seem to print to any of the printers. What do I need to do to continue using a wirelss router and print to the already functioning printers?
    Scholar:
  • 60 Answers
Usually wireless routers prohibit master browser (network neighborhood) communications from traversing between the wireless and wired computers. You can usually overcome this by setting a static ip address for the computers with the printers so that they are not a moving target (addresses are always changing with DHCP). Then you can use UNC paths to get from wireless computer to your target on internal network. For example, to connect to printer (with shared name BrotherH) on a wired computer with static ip address of 192.168.0.19, on wireless computer create a network printer and manually enter the address \\192.168.0.19\BrotherH , now the wireless computer should be able to traverse and connect to the wired printer.
Your wireless router should have a pool of static ip addresses available, say 192.168.1.1-49, you can specify this to your liking, and then you can also have a block of handed out DHCP numbers, say 192.168.50-60 or whatever.
Posted on Jan 26, 2009
I have a very old HP LC3 netserver. It was in my office, and I have moved it to my home. I would like it to communicate with my printer in order to print out documents. Can it be connected directly to my...
Add the printer to the wireless router as another node via DHCP. Then add the printer by the IP address. Your server does not have wireless so it will need to be connected to the router via network cable.
Or, you attach the printer directly to the server via parallel port (RS-232) cable. Or upgrade the server with an USB port, and connect it that way. gl
Mar 23, 2013 | HP NetServer LC3
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
I have my Canon MX420 printer hooked up, my computer recognizes it's existence, and the printer prints fine by itself. However, every time I try to print from my computer via wi-fi, my computer says...
If your printer has the network cable plugged into it then your halfway there. Make sure that as well as having a hard line network cable plugged into your router, you need to connect the printer to the wifi signal as well. On your printer, push your settings button, scroll to your wireless lan setup, and connect to your router and if password protected, enter in the password and you should then be connected to you router, now try printing using your laptop or device through your wireless connection, and it should print. Please post back if you need further instructions or help!
Aug 24, 2011 | Canon Pixma MX420 All-In-One Printer
How do I connect my Action tec router V1000H to other computers to be able to print to ne printer. Iam running widnows 7
1)make sure that the printer is capable to be a network printer.
2) make sure that your able to print with main computer on the network.
3) make sure that the printer was able to detect the network via wireless connection ( if the printer have wireless capability) ( if not then it should be connected with a ETHERNET cable directly to your router)
4) make sure that the other computer already have the driver of the printer.
try using this first and if this will not work try sending me a message so that i can give you some more steps.
(ramiroreulin@gmail.com)
Apr 10, 2011 | Actiontec (5GE583000-01) Router
How can I connect my printer to my wireless network
If you have a wireless-enabled printer, you can use the printer's configuration to connect it to the router. If you have a wired connection printer (ethernet port) connect it to one of the ports on the back of the router with an Ethernet cable and the printer should sort itself out. If your printer is not network-enabled, you will need to connect it directly to a network-connected computer, then use Windows' sharing settings to share the printer to the network.
Hope this helps, Alistair
Mar 15, 2011 | D-Link DIR-615 Wireless Router
I have a wire less network set up and want to use my lexmark x1270 so i can print wireless but cable is USB and do i need to get a cable to put into my router or??
You can't set it up wirelessly, persay. but you can use a special bluetooth adapter in the "pic bridge" slot on the front. I have seen them on e-bay from £5($8) to £12($17) or so.
Oct 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
Linksys Wireless-G WRT54G Router Logo
118 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
