Question about HP Photosmart C5580 All-In-One InkJet Printer
Blue error screen with B307C894 - HP Photosmart C5580 All-In-One InkJet Printer
Dell inspiron 570. 1 beep on start up. black screen. 1 light on the front
if you need support for your Dell inspiron 570, Blue Screen of *****, Fix Blue Screen Errors, Blue Screen Error in Computer, Blue Screen Error in Laptop, Dell Technical support Number, Dell computer support, Dell laptop support Number 1-800-204-4427 (toll-free) and more... http://www.delltechnicalsupportphonenumbers.com/blue-screen-of-*****
Jun 24, 2017 | Dell Computers & Internet
Tip
How to Fix Blue Screen Errors (BSOD)
<p>Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.<br /> <p>There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.<br /> <p><b>How to analyze blue screen errors</b><br /> <p>The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.<br /> <p>Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.<br /> <p>Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.<br /> <p><b>The most common cause of blue screen errors</b><br /> <p>In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.<br /> <p>So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.<br /> <p>If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.<br /> <p>If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.<br /> <p>In most cases updating or reinstalling drivers will solve your blue screen errors.<br /> <p><b>Other causes of blue screen errors</b><br /> <p>However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:<br /> <p>Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.<br /> <p>Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.<br /> <p>Update Windows - missing updates, including service packs can be a source of stop errors.<br /> <p>Check your system - run a virus scan and spyware scan after updating your definition files.<br /> <p>Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.<br />
on Nov 29, 2010 | Computers & Internet
HP C5580 will not start up completely. It either freezes while trying or I get a blue screen on the printer that shows a power button and gives quite a variety of codes. Example...
I had this same issue. I had attempted to resolve it with the directions above from Mohammed. This worked one of the 8 times I had to reattempt shortly thereafter. I contacted customer support, and he stated that it was a hardware issue within the printer and offered to "replace" it. Since it was out of warranty it would be replaced with the Photosmart C5520 at a cost of $100.00. At the time of offer a 2 second search showed this same model was available from amazon for 97.50 brand new. So in all reality if its under warranty still your golden. If not, your Shitouttaluck.
Jun 10, 2011 | HP Photosmart C5580 All-In-One InkJet...
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
How do i fix my computer with a blue screen that keeps shutting it off?
Post your OS please!
Oct 01, 2010 | Computers & Internet
I cannot load windows it gives me the blue screen than dumps the memory
There are many possible causes for blue screen errors. Faulty memory, device drivers, viruses. Try to analyze the blue screen error by looking at the error code and the event log, so you can find the right solution.
Here are some ideas: http://www.pcauthorities.com/pc-errors/how-to-repair-blue-screen-errors
Jun 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
Why my laptop always blue screen after play games
try to reinstall the videocard drivers or your laptop is not recommend for gaming or replace memory card
Aug 16, 2009 | ASUS LGA775 SOCKET FOR INTEL CORE2...
Blue screen is coming
There are 3 step to repair blue screen error If you got blue screen error then there is a 94% chance that your computer has registry problems. To repair blue screen error you need to follow the steps below:
  • Step 1 - Download a Perfect Optimizer,install this error repair tool.
    * Step 2 - Click the Repair All Button.It will scan you pc for Free.
    * Step 3 - Then click the Repair All Button again and your done! It is very easy to repair blue screen error.
    Here are the url of Perfect Optimizer: http://www.errorremovers.com/tidporp-blue_screen_error-zz0005
Jun 04, 2009 | Microsoft Windows Vista Ultimate Edition
HP Photosmart C5580 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
