Question about Nokia 3120 Cellular Phone
Ringer not work
Ihave a nokia 3120 but its ringer is not working ,pl help me out
Try to check the buzzer,if ok,go to check the buzzer lone...
Posted on Jul 18, 2007
Hi. I change and forget security code for my Nokia 3120. Ihave IMEI 353102027869731. Help my please.
If you forget the security code means get the master reset code for your nokia mobile, because does not remember security code you have to reset your mobile its a only way to use the mobile, so get the master reset code for your Nokia 3120 model mobile from this site Unlock-free.com, it has the best services for the master reset code for your nokia mobile.....I hope this may helpful to you.........
Sep 19, 2011 | Computers & Internet
My Nokia 3120 Ringer Problem Ringer not working
If you can't the ringer of your phone,check the settings on your profile if its activated and volume is up,otherwise,it seems your buzzer/speaker is the problem,sometimes when the phone gets drop on the ground, buzzer contacts may be dislocated or probably need a buzzer replacement.
To work with this problem and can DIY,
* you need a T6 precision screw driver or any tool that can release the screw.
1. Remove the battery cover
2. Remove the battery pack.
3. On the front panel/housing,release the 2 clips on the bottom using even your thumbnail and lift up the front housing.
4. release the 6 screw using the said tool.
5. lift up the entire module which is the LCD with frame and together with the mainboard.
6. On the back housing,you will see a 2 gold plated pins on the upper potion,that is seems to be the connector were the buzzer is connected and hide underneath.
7. clean it first,check if there's a corrosion and align it as well.
8. located the interface were the 2 metal pins is align connected unto the board.clean it as well.
9. Now assemble the phone and try if it is working then.
If not working,need a parts replacement and this could be possible if you bring to the a mobile service shop near you for replacing the said part.
Hoping this method helps you in a way. Thank you for visiting FixYa.
Jul 16, 2011 | Nokia 3120 Cellular Phone
I want to update my nokia 3120 classisc phone. From where i can update pl tell me ?
im sorry there were never any updates released for this phone why do u need to update it anyway please make payment to me as soon as possible
Jan 19, 2011 | Nokia 3120 Cellular Phone
3120 ringer ic jp
tell your problem clearly please!
Jan 14, 2011 | Nokia 3120 Cellular Phone
Ringer of nokia 3120
what is the problem? please add more details so that we may help you
Oct 04, 2010 | Nokia 3120 Cellular Phone
Kg195 ring tune ic connection
kg195 ringer ic same to nokia 1600 ringer ihave change 100% work now kg 195 ringer ic problem solve here try and say thnks
Sep 15, 2009 | Cell Phones
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
Ringer problem
it may be due to some small loose connection. remove the connections once and re fix them again.
May 31, 2009 | Nokia Cell Phones
Nokia 3120 NO SOUND
there can be problem with ur fitting of phone, may be screws are loosen, or ringer is faulty or ringer ic also can have problem. open rintones play anyof ringtone, then press gently on left side in centre of phone, i mean press its case infront of green button ,then check if sound is coming if comes then screws are loosen, if don't come, then u need to take it to technician.
Feb 22, 2008 | Nokia 3120 Cellular Phone
Nokia 3120 Cellular Phone Logo
145 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Laxman Bisht
Laxman Bisht
