Question about Kenmore 88732 Top Load Stacked Washer / Dryer
Have model 88675 with slow hot water fill
Hi! I've trolled the internet to find the solution for my particular problem in this Kenmore stackable washer/dryer but have yet to find the solution. My washer has no problem loading cold water, but the hot water is so slow, it takes nearly 20 minutes for hot water to fill up! I've seen answers to a slow fill for water period, but it does not mention just a hot water fill problem. Does it need something that the cold water hose doesn't?
  • 883 Answers
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Posted on Jul 17, 2007
SOURCE:
I have a kenmore 600 series tl washer. it will only fill with water very slow
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 09, 2011 | Kenmore 98702 Stacked Washer/Dryer
Hi I have a problem with my Kenmore washing machine,in particular I can not use hot water anymore. When I use my washing machine hot water does not stop at set water filling level (law, medium,high)...
Please post the model number for your washer. It sounds like your hot water valve has failed and is not closing. Unplug your washer's power cord and turn the hot water spigot that comes out of the wall on. If you still get water filling your washing machine, it's definitely the washer's valve and you will need to install a new set (hot and cold valves are both part of the same assembly).
Mar 11, 2011 | Kenmore Washing Machines
Kenmore hd 80 series,extra capacity plus. cold water will not fill tub?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Jan 23, 2011 | Kenmore Washing Machines
Why does my washer not fill on the hot water setting?
heatman101
Oct 06, 2010 | Kenmore 24032\24036 Top Load Washer
COLD WATER WILL NOT FILL; NO COLD WATER RINSE. MODEL NUMBER 110 26452502
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 08, 2010 | Kenmore Washing Machines
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
315 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
