Question about Salter Aquatronic Glass Platform Electronic Kitchen Scale
Salter 3003 error
Ee
My Salter model 3003 kitchen scale shows Err when I turn it on. How can I fix this?
This means that it cannot calibrate itself because the sensor is out of range. This can happen if you drop it or overload it. Check the feet on each of the for corners and make sure they are not stuck, you can do this with the unit on and see if it registers any force on the pads when you press and release them or use a screw driver to lift them SLIGHTLY. There are a lot of youtube videos on how to check and repair them.
Jul 30, 2016 | Salter 3003 Aquatronic Glass Electronic...
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
EE showing on screen
Sep 12, 2014 | Salter 2001 electronic kitchen scale
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
The display on my salter bathroom scales is flashing error, i have changed the batteries, this did not help
I held the two arrow and set buttons together for a few seconds and it cleared
Oct 19, 2009 | Salter Health & Beauty
Setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Oct 06, 2009 | Salter Bakers Dream Aquatronic Kitchen...
Thermostat shows error on unused zone
You will need to take the inside cover down on the front air conditioner. There is a control box mounted there, open the control box and you should see many dip switches on the face of the board. Make sure that Zone 1 and Zone 2 are selected (furnace as well if your furnace is fed through this thermostat). After making sure that the switches are set, turn off the thermostat and hold down the mode and zone buttons at the same time, turn the tstat back on. When EE appears on the face, release the buttons and see if everything works. If not, then I would say that you have a bad control unit in the air conditioner.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Salter Aquatronic Glass Platform Electronic Kitchen Scale Logo
29 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
