Question about Music
Galanti organ GALANTI MODEL "PRAELUDIUM 2" ORGAN
Baldwin organ model 48c stops don't work
Look up an "organ repair" business in you phone directory.
Also, look up Baldwin organs in your search engine of your computer, and call the factory or an advertising dealer, and ask them what they recommend.
God bless your efforts.
Jun 05, 2018 | Music
Can you tell me how to find a Baldwin Organ Model 48c owner's manual?
Try Googling (Baldwin)(48c)(manual) without parens.
Mar 20, 2018 | Music
I need a manual for a Ahlborn-Galanti Chronciler organ where can I find one?
Your best bet would be to contact the manufacturer. Here is a link to their contact info.
Ahlborn Galanti MITA International
Feb 11, 2015 | Music
How to replace broken Organ keys
It varies from one manufacturer to the other, and even from model to model from the same company. No matter what, it will require removing part of the organ's cabinet to get to the screws holding the plastic key to the metal key finger. If you are unfamiliar with the procedure, I would suggest hiring an organ repair man. It's too easy to cause more problems doing it yourself.
Feb 05, 2015 | Music
Can I ship an organ on it's back?
Depends on the make and model. A all electronic organ with very little mechanical components should be fine. The older Hammond organs do not like to be tilted to far of the vertical. What make do you have?
Dec 21, 2013 | Music
Need a manual for old hammond organ model 122126 romance model or 1977 or 1978
You might try the ORGANFORUM.com as there are a lot of organ players there and quite a few with Hammonds. Finding an original copy is probably out of the question, but a duplication probably can be found.
Jul 15, 2011 | Hal Leonard Classic Hammond Organ Know the...
How do you fix a tune board for an Organ? Or do you have to replace it? How much will replacing cost? It's an old Organ from the '80s, the sound is there it is just off tune: robotic or broken.
You didn't tell us what brand or model organ... If the organ is digital, then it likely has a pitch control or paraameter to set it for A440...
If it is analog type organ, then components could be adjusted or replaced to fix the problem.
Dec 06, 2010 | Music
I purchased a used Hammond Organ Aurora, Model 700, 710 C125 but the previous owner did not have the manual for it. I am looking for a manual so I know how and what to do to play it. I don't know what...
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Nov 23, 2010 | Music
110v is pluged to 220v. What part of the organ damage?
This totally depends on what organ you have.
Many would blow the input fuse. Some organs have a wide range power supply that would use either 110 or 220.
What model is it?
Apr 15, 2010 | Yamaha Music
I have lost the manual for my model SX-K150 Technics organ.
Get the manual there, they will find you every Technics handbook.
Sep 14, 2009 | Music
Music Logo
76 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
