Question about Sansui COM3101 13" TV/VCR
Screen turns black except for one inch around the outer edge
It happens after the tv had been on for 15 min. You can push almost any button and it goes away for about 5 sec. The orginal picture can still be seen around the edge during the black out. Can you help.
Thanks
  • Sansui Master
  • 520 Answers
Use the tv/cap/text button to turn off the text box function of the closed captioning.
Posted on Feb 06, 2009
What is the reason for my E701i-A3 failure? All boards were replaced, worked for a minute, and then had the same "fade to black" failure as the first time.
Your back light controller board or the ballasts for them may be bad if they weren't incorporated into the power supply board.
Dec 05, 2016 | Televison & Video
Won't completely shut off
Do you have a separate Cable Box? It sounds like you are shutting off the signal to the TV and may have to push a 'TV' button the remote then the 'off' button to actually shut down the TV.
Nov 21, 2013 | PixiModo Reflection 15M 15-Inch Digital...
Black box on JVC screen
a black box is covering my tv screen except for around the edges. I can use the dvd player, but i cannot watch cable. it is as though there is a security feature to block tv, but i cannot get it to go away!
Jul 11, 2009 | JVC AV-32D305 32" TV
Blue screen on my haier 37 inch tv
my tv just went to a blue screen one day. I can turn it on and then it will just remain on the blue screen. Any button (except the volume) I push on the remote comes up on the screen "no signal". What would you suggest? I have been reading about replacing a fuse or board? Most of those are on the 42 inch version---I have teh 37 inch version.
Feb 02, 2009 | Haier HL37S 37 in. LCD HDTV
My screen randomly blacks out.
the best method to overcome this problem is format the computer!!! i too used to get the same problem!!i did format it...!
Dec 30, 2008 | Microsoft Windows XP Professional
Black box
It is the closed caption.If you have the remote,press the button marked CC.Keep pushing it until it says CC off on the TV.It might take around four pushes depending on what CC mode it is in.I hope this helps.Please let me know if you have any questions.Thank You very much!
Tyler
Sep 12, 2008 | TruTech PLV16320 Television
A black box appears on the screen
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
Jan 15, 2008 | Haier 20" TV/DVD Combo
Black out screen
I had the same problem once with my RCA television. It only happened on certain channels and didn't happen during commercial breaks. If I adjusted the volume on the tv the box went away, but came back shortly after. The problem ended up being some malfunction in the closed captioning. I turned it all off and changed the CC settings and never had the problem again.
Oct 05, 2007 | Westinghouse W33001 30 in. HD-Ready LCD...
Black square covering up most of the screen
Try goeing into your Menu and see if you have the closed Caption on that will produce a black box on the screen if you have the owners manual look in there,if you don't have it you can go on line and download it from the manufactures website under Downloads Good luck Walter Grzybowski
Sep 17, 2006 | Philips 60PP9202 60" Rear Projection...
Sansui COM3101 13" TV/VCR Logo
80 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
