Question about Microwave Ovens
Plugged in 15amp cord on new omega oven my son bought me but has no power
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 12 Answers
May the cord is bad or you trip the breaker
Posted on Jan 20, 2013
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
I have bought a whirlpool microwave wmh1163xvs. where does the power cord exit the oven and where should the plug in be located?
Typically the power cord on above the stove microwaves exit from the top of the oven. That way the oven can be mounted to the wall and the power cord can be routed up to an outlet in the cabinet above the microwave.
May 02, 2010 | Whirlpool MH7140XF Microwave Oven
Microwave trips circuit breaker when plugged in repeats when breaker is reset . There is no problem with house electric.
The circuit is probably a 20Amp circuit (see the number stamped on the circuit breaker switch). Most likely, it is the same circuit as the refrigerator, crock pot, window A/C unit, etc....
Also, if you are using an extension cord or a power strip or a surge protector. Those may not have a high enough power rating.
One other possibility (not likely) is that the circuit breaker is a 15Amp and the microwave is 1500 watts.
What else is cut off when the circuit breaker is tripped?
Solution is to use a different outlet for the microwave, or turn off any other applicance in the same circuit (except the refrigerator, of course).
Hope this helps!
Sep 16, 2009 | Microwave Ovens
Jenn-Air M166 quit, no power
Took microwave out, opened back, 15amp fuse blown. Replaced all ok.
Jul 06, 2009 | Microwave Ovens
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Kenmore Microwave Oven Sudden Power Reduction
I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady, I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84 here.
Feb 14, 2009 | Kenmore 62622 Microwave Oven
Power cord
If you are referring to the main power cord then you should be able to purchase one at Home Depot/Lowes of most local hardware stores... make sure you get the current rating off the tag on the appliance.. 15Amp or less can use a cord size of 14 gauge.. you should use a 12 gauge for any appliance requiring up to 20Amps ( in your case ..1100 watts minus losses within the system should allow you to use 14 gauge power cord.)
Sep 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
GE Microwave - Power Cord Appears to be Dead
Most microwave ovens are equipped with an internal fuse. This is typically located where the power cord enters the cabinet. The cabinet will have to be opened to verify the fuse.
The magnetron is not directly attached to the power source, it has to be stepped up in voltage significantly, either through a transformer or inverter.
It is usually best to have professional tech check the fuse for operation. Most shops will do this for a small fee if you drop the unit off yourself.
Jul 28, 2008 | GE JE1860 Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
