Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Copier wont print color picture from computer
Just prints end of picture with minimal color. both inks have been replaced twice with same problem still happening
    Sergeant:
  • Kodak Expert
  • 285 Answers
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free. I hope this helps.
Posted on Jan 28, 2009
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
The color is not adjusted right.
The first step is to determine whether the problem is in the printer or the driver.
Run an alignment test and then, using the printer menu, print a picture that is within the printer.
If the internal picture has the same problem, and all ink cartridges are flowing properly (you will be able to tell from the alignment test), printer replacement is going to be the least expensive repair.
If the internal picture prints ok, then try printing a picture from the computer again. If that gives you the old problem, disconnect the printer from the computer. Then, uninstall the printer, reboot twice and reinstall the driver, hooking up the printer when asked.
Jul 28, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Color of the picture printed out is not the same as the printed
Your printhead has failed. Call kodak for a new one. They are aware of the problem.
Feb 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Changed color cartridges and now the color wont print
Make sure that you peeled of the piece of plastic that is in front of the nozzles.
Dec 24, 2008 | Epson Stylus C86 InkJet Printer
Blank pages
Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
Dec 21, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
57 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
