Question about British Telecom BT BIG Button Corded Phone
Cant use phone to make calls
When you lift the phone to make a call there is no dialling tone at all. yet when i phone the number from a mobile it sounds as if it is ringing but it isnt
  • Anonymous Apr 01, 2009
    I have the same problem, but everything seems to be plugged in. It's very frustrating because we cannot afford to have someone come look at it. I've checked every where I could think of, could it be a telephone line that's down somewhere else? Or the company?
  • 79 Answers
If you hear the phone ringing when you try to call from a mobile, that means your connection is still active at the local exchange, but does not necessarily mean your phone is plugged in or ready to accept calls. Most probably your phone is disconnected somewhere in the internal wiring within your premises or the phone instrument is dead or wiring is faulty outside your premises.
Posted on Jan 26, 2009
Why does the phone not call out ? It says the way the number is dialed doesn't work?
Did you read the instructions that came with it? I am wondering if you have to dial 9 to get an outside line if this is a home PBX unit?
The other possibility is that the phone is not set to tone dialling and is set to pulse. When you dial, do you her musical tones or clicks corresponding to the number dialled?
Comment back with Make and Model as a comment to this post.
Nov 24, 2015 | Lands Phones
Phone was played with by child, now red light shows and no dial tone
Hello
Your phone ahs been locked by mistake. When telephone is locked, except for a saved emergency number, no numbers can be dialled; incoming call can be answered.
To unlock it, Lift Handset, select function. (1) Lock. (0) Unlock. Press SET key and replace handset. OK.
Aug 30, 2011 | Siemens Euroset 5010 Corded Phone
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
Nokia N72 mobile phone, am unable to hear dial tone when dialling and unable to hear incoming call answering a call and unable to from them when I make outgoing calls.
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
Jul 11, 2009 | Nokia Cell Phones
Cannot get dial tone
try to make an incoming call to the phone in question by dialling the phone number from a mobile or whatever.if the phone does not ring then the line itself is not connected or has a wiring problem.
so if no dial tone and no incoming calls then check the line itself
Dec 20, 2008 | Lands Phones
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Speaker key and deleting voice mails
you hit the speaker button on the left side of the phone and the pad shows up...
Apr 22, 2008 | LG Prada KE850 Cellular Phone
British Telecom BT BIG Button Corded Phone Logo
148 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
David Burbee
David Burbee
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
