Question about Casio QV-R41 Digital Camera
Memory Card Locked
I have tried 3 different memory cards and not one of them will work. It says card is locked and nothing even moving the sliding part on side of card works. Any ideas out there please.
    Sergeant:
  • 274 Answers
Do you have a computer that will read the "memoery cards"? Try reading the cards. If there is nothing on the card you still should get a message telling you the status. Check the setup of the camera. Some cameras allow you to lock the memory card from setup memu. You might also need to "format" the card before you use them.
Posted on Jul 17, 2007
  • Jerry Hess Jul 17, 2007
    Look in your manual:
    Refering to page 138-139 of the maunal, try "formatting" the cards before using them. Make sure the "slid lock" on the card is in the "unlocked" position. Format using the camera not a computer under "setup tab".
    You might also try turning the "protect files" to "off" until you get the cards to work.
    Hope this solves your problem.
SOURCE:
Screen says Card Locked..
Check your memory cards. If you are using SD cards, there is a small slide-lock on the side of card. Move the slide away from the LOCK icon, re-insert the card in the camera, being careful not to cause the slide to move again, and you should be able to use the card normally.
Apr 17, 2016 | Konica Minolta Cameras
Memory card error locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Does moving the switch make and difference?
Aug 19, 2013 | Canon PowerShot A610 Digital Camera
Memory locked is displayed on the screen... I tried the switch on the side and still it wont work. Even tried another memory card still have the same problem. How do we fix this. Cam model is power shot...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". There are also other common causes if moving the slide switch didn't help, with troubleshooting steps for this problem listed here.
Sep 11, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
When iput my sd card in my camera it says card locked even though the card isnt locked what can i try
There are several possible causes for "memory card locked", "memory card error", or "no memory card". If moving the tiny slide switch on the card didn't help, see other troubleshooting steps for this problem listed here.
Sep 03, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have a Casio Exilim EX-Z80A and it shows that the SD card is locked. I tried sliding the thing on the side of the card, but nothing. I even put in a different card, but it still shows Card Locked! Please...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (note 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 16, 2011 | Samsung Digimax A400 Digital Camera
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Apr 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
Locked Memory Card
on the side of the memory card theres a little slide thats normally a differant colour to the rest of the card just move this slide to its other position
Mar 25, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Memory card locked
I had the same problem and it took me forever to figure it out! On my memory card there is a tiny slider that slides up and down. Mine was slid to "lock" I just slid it back and it was no longer locked! Sounds simple enough now that you know, huh?
Aug 23, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Casio QV-R41 Digital Camera Logo
80 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
